I haven't broken another Turbo bolt yet, I separated the wastegate to a separate screamer pipe and added a stainless flex in the DP (there's one right near where the exhaust bolts up but trying to be overly cautious here).
I also rerouted all of my ISV plumbing so that it now draws from the intercooler piping. I had suspected a leaky ISV and finally getting to an intake pressure test made this obvious.
I played with my cam timing- definitely NOT the problem.
Do have a bit of noise coming in on the crank sensor signal.
Sorry I'm rambling but check it:
I think I'm finally almost where I should be!
