Posted: Sat Jan 06, 2007 1:52 pm
Toxcheap wrote:Video links work now![]()
your welcome Marc
yah, I renamed the photo gallery when I accidentally typed '06' and meant '07', which broke the links. Thanks
your welcome Marc
1 Large volume fan (42 inch)timmmy wrote:Sweeet - Nice work Mark and I cant wait to see what the difference feels like
What sort of cooling do they have there for the airflow over the motor?
H
p.s. Ambeint 69.8 degrees F - January 5th in New England....>Gotta love global warming!!!! (it should be about 15F for all you non NewEnglanders)
Plan on building a female fiddle sticking machine?nerdhotrod wrote:Instock electronics + Playboy = all you need for a relaxing bathroom experience![]()
Thanks again Marc, we had a great day!
Only if it's got over 400hpnerdhotrod wrote:Why?
Think there's a market for one? :-D
enough to qualify for 'in need of professional help' statusquattrofrog wrote:Thats some good "get-er-done" power... lol and congrats on acquiring yet another Audi... so how many do you have now?
dont forget your 'intercooler sprayer' that looks suspiciously like an insecticide sprayer (I took a pic, but my memory card trashed that one for some reason :()nerdhotrod wrote:1 Large volume fan (42 inch)timmmy wrote:Sweeet - Nice work Mark and I cant wait to see what the difference feels like
H
4 Small very high velocity fans (great for intercoolers)
a4kquattro wrote:034 flying lead harness (which is usally included with the ECU)S4turbo wrote:Marc, just wandered what you needed of bits and pieces for the conversion to 034 management. Does this list cover it:
IIC ECU
Crank pully combo (034)
1,8 T temp sensor (034)
VR extension cable
Cables for connecting the IIC to the Motronic harness
JPT55 connector
Epoxy for filling the connector
Did I miss any important sensors or items that would be nice/necessary to have?
I dont get an 'idle up' when the AC is on so it idles a little rough running the air conditioning but thats about it. instrument cluster still works, etc.Have you lost any features from the original car from the IIC upgrade? I konw knock sensors are not in use, bur what about AC, instrument cluster?
yes, you need a 60-2 wheel on the crank pulley for this system to work.S4turbo wrote:Bumping this one...
So when you are using wasted spark, do you still need the cranc pully combo?
nope. I am currently not using the cam position sensor at all.I have an early AAN, where the hall sensor (?) is in the "dizzy" box or what you call the distributor position used in the 3B. Are there any differences in how the IIc should be connected to this engine compared to the later AAN engines?
yep, more boost. I'll be going back on the dyno in a few weeks to help Brian Weldon (SpoolinS6) tune his car. After we finish with his car I'm hoping to bring boost up closer to 28-29 psi.S4turbo wrote:Great numbers Marc!
What is next, more boost or are you satisfied??
Regards, Johan
Sweet now your talking!!!!a4kquattro wrote:yep, more boost. I'll be going back on the dyno in a few weeks to help Brian Weldon (SpoolinS6) tune his car. After we finish with his car I'm hoping to bring boost up closer to 35-40 psi.S4turbo wrote:Great numbers Marc!
Regards, Johan
Toxcheap wrote:Sweet now your talking!!!!a4kquattro wrote:yep, more boost. I'll be going back on the dyno in a few weeks to help Brian Weldon (SpoolinS6) tune his car. After we finish with his car I'm hoping to bring boost up closer to 35-40 psi.S4turbo wrote:Great numbers Marc!
Regards, Johan![]()
Toxcheap wrote:Sweet now your talking!!!!a4kquattro wrote:bring boost up closer to 35-40 psi.![]()
I'll have it buttoned up for the 29th, no problem.nerdhotrod@epl wrote:Yikes...
