16v head-studs are en route!
Also scored an intercooler from ryan’s, its good to have spare performance parts lying around haha
Its about 22 or 24” core length, about 8” high and 3.5” thick, yes more overkill, but its mostly so im ready for a big turbo. We welded in an additional support bar to hang the IC from in the center support, I will add to this to mount my oil cooler most likely. Pics!
I have since received a full set of b3 90q wheel bearings, and while the knuckles and hubs are apart im getting them powder coated in low gloss black mostly for durability. They will get coated and reassembled and installed onto the car.
I gots me another urS4 o1e to put in ( jsut need to whip up some custom mounts) , linkage is done from when I was 7a/o1e’ing the car, and I’ve acquired b3 80 front ball joints to use in my b2 c-arms and 2 piece b3 knuckles and uprights. I also sourced a set of b3 90q 20v springs and fresh 034 street strut mounts.
So with the above suspension setup I will be able to use off the shelf b3 90q axles, SWEET!!
In my small bit of spare time this winter I was able to fabricate up a nice oil catch can out of a piece of 3.5” straight and a AC drier can. It has qty. 2, 10AN inlets, one for VC and one for the crankcase, also a ¾” K&N breather filter for it as well, just need to get it mounted up, here’s some assembly pics, ill find the finished pic soon. there is a 1/4" npt drain petcock, not pictured to be installed as well
