Tacos 4KTQ I0vt Swap: The Red Baron - buying parts again
Re: Tacos 4KTQ 20vt Swap: The Red Baron - MOAR PICTUREZ!!
Got the junker FA installed just now. Finishing up lunch then taking it for a drive
FUCKING SERIOUSLY!!??!?!????!!
There I welded it back together in the middle of the carwash parking lot.
That literally happened 2 hours ago. This damn car is trying to tell me something. Also found why I'm getting creep. The damn banjo bolt fell out of the wastegate!!!!!!!!
- themagellan
Shifter linkage? How did you manage to weld in the parking lot - do you bring a flux core mig with you lol?AngryTaco wrote:FUCKING SERIOUSLY!!??!?!????!!
It's telling you to maintain it!
Re: Tacos 4KTQ 20vt Swap: The Red Baron - I HATE THIS CAR
Yeah flux core saves the day! I thought I had an extra one still attached to my 3.89 5ktq trans at the storage unit so I ran up there....discovered NO linkage....so grabbed the welder and did it right then and there at the car wash where it broke!!!
Wilfred,Wilford Brimley wrote:I had my boost set at 17, and it would creep to 20 if I was in 4th or 5th.dana wrote:do you have experience to back this up, or is this just a theory? I used a 20vt WG on my car, and never had an issue with boost creep. My car was around 350whp, maybe more at 30psi.Wilford Brimley wrote:Another likely scenario is the stock 20vt WG being unable to bleed off boost with the tiny 30mm plunger when loaded up in a high gear. Check to see if there isn't a tear in the WG diaphragm too.
You also have to remember that this is on a 20v, which has an awful exhaust manifold design when compared to the 3b/AAN. Not all of the cylinders even feed the WG...
17 psi with what turbo?
Wilford Brimley
K26/T04e
The old "K26 H.O." that 034 sold a while back.
Man, those 10 valves are just trouble man.
Seriously though, keep at it, you'll get all the issues sorted!
So I am now so exhausted and tired because of this car, I am merely laughing and chalking today as "God's Wrath".
10 miles into the cruise, I get on it hard going up hill and then I lose all power with a HUGE smokescreen suddenly behind the car. Check the engine....fucking igloo popped off the CIS dizzy. The cylinder rings were already smoking, so I pretty much expediated the death of the current ones.
THEN as I drive back to the storage unit 35 miles away to get the v8, I put my code in at the gate, go to put the car in gear.........won't shift into gear and grinds like a MOFO just trying to get into 1st. Clutch is now completely shot.
All this happened today after I broke the shift linkage, discovered a missing banjo bolt to the wastegate, and put $40 in the tank. Guess the 3.89s, clutch, rings, etc and possibly VEMS are getting expediated now. God I hate cars
Man, this was turning into a good day for me, and a shitty one for you. Sorry to hear that you lost another set of rings/pistons. I hope the V8 holds up until you can get this back together.AngryTaco wrote:So I am now so exhausted and tired because of this car, I am merely laughing and chalking today as "God's Wrath".
Dude, you just need to go 20valve already.
That freaking sucks though, you were just getting it back together!
Sorry to hear that man. You have been through hell with that car...
Looks like I'll be tearing the head off.....AGAIN Monday. Oh well. Only par for the course.
Re: Tacos 4KTQ 20vt Swap: The Red Baron - BLOWN RINGS AND CL
By now you're down to what, sub-9 minutes to pull the head?
Just about. 10 if I stop to have a beer
- themagellan
I almost felt bad for you till I realized you have a running and driving audi v8.
man whateva.
man whateva.
lol, I have NEVER seen somebody have so much trouble with a simple CIS 20vt swap
Sorry bro!
Sorry bro!
Sucks Jared, I'll buy a VR6 keychain if it makes you feel any better
You're damn right it will make me feel better! LOL
It will go to funding the either the re-ringing if the pistons arent shot, or the new build
I will say this however; this car pulls FUCKING HARD on 16psi with the CIS and Turbo setup. It will go from 70-120 in like 4 seconds. Nucking Futs
I'll buy 2 if you swap a 20v in
Send me an invioce
Send me an invioce
Re: Tacos 4KTQ 20vt Swap: The Red Baron - FIXING TIME!
So it's looking like I'm going to start the rebuild process....AGAIN....lol
I will soon have a Southbend Stage II OFE clutch on the way. I think I'm just going to have to bite the bullet and order a lightweight 20vt flywheel from 034. Not happy about it, but I don't know of any other options.
Hank says he may have an aluminum MC1 flywheel running around so we shall see.
I'm going to start working on the body while the car is down, as the exterior needs work badly. It's about time the car started looking like someone has a bunch of time and money into it
Why not just run a 3b flywheel? Is the clutch 20vt specific? If so, i didn't know a "lightweight" 20vt flywheel existed? the heft to them are the raised outer edges, and if you have a 20v flywheel specific pressure plate you'll need those raised edges for it to work.
I AM CONFUSE
I AM CONFUSE
The MC1 flywheel is a very heavy dished flywheel. The pressure plate is built to match it. The MC2/3B fly wheel is the thin plate like flywheel that uses the same type pressure plate as 01A cars.
Yeah I understand that. The question, is what is the pressure plate for? I'd imagine mc1 since the 20v clutch kits are crazy cheaper than 20v clutch kits.
But 034 also doesn't make a LW 20v FW AFAIK?
Wow. Worse luck than me. Don't know how you can still be so dedicated to this car, lol
http://store.034motorsport.com/flywheel ... 20928.htmlpilihp2 wrote:Yeah I understand that. The question, is what is the pressure plate for? I'd imagine mc1 since the 20v clutch kits are crazy cheaper than 20 clutches.
