Page 2 of 13
Posted: Tue May 11, 2010 7:38 am
by oldsklaudidub
This is starting to look a lot like the General Lee 4kq on youtube
Posted: Tue May 11, 2010 7:44 am
by my2000apb
WOMBAT wrote:hahaha yes safety orange!!
hells ya!!! it still needs more clear but i had to get it done up quick to move it from one garage to another, and its really hard to drive with newspaper all over teh windows
Posted: Tue May 11, 2010 7:52 am
by my2000apb
hmmmmmm maybe the General John Stark ahahhaahha
Posted: Tue May 11, 2010 8:13 am
by JasonAG
ah.... this must be the car your wanting my parts for. i dig it!
Posted: Tue May 11, 2010 8:16 am
by my2000apb
JasonAG wrote:ah.... this must be the car your wanting my parts for. i dig it!
oh hells ya
Posted: Tue May 11, 2010 11:52 am
That picture of the donuts is very sweet. I like the project. Get er done!!!
Posted: Tue May 11, 2010 1:50 pm
by my2000apb
ShavedQuattro wrote:That picture of the donuts is very sweet. I like the project. Get er done!!!
jahhahaha thanks, we finally stopped the donutage and started to drive away and i was liek daaaaaamn that looks like a Q, time for a pic!!!
Posted: Tue May 11, 2010 6:45 pm
by glibobbo21
in the pic it looks like you just edited the pic in MS Paint lol
Posted: Tue May 11, 2010 8:52 pm
by my2000apb
glibobbo21 wrote:in the pic it looks like you just edited the pic in MS Paint lol
oh i have plenty of pics to prove it
Posted: Wed May 12, 2010 5:50 am
by glibobbo21
when u gonna drive it its taken you like 2 weeks to paint it?
Posted: Wed May 12, 2010 6:01 am
I want to see some more pictures! :woowoo:
Posted: Wed May 12, 2010 7:23 am
by my2000apb
glibobbo21 wrote:when u gonna drive it its taken you like 2 weeks to paint it?
i amy be needing a slave cylinder for the clutch, firewall brace works great but its still unwilling to pop back up after the pedal is depressed
so i could drop the trans and pop my old one back in so i dont have to try and swap the old one out while the trans is in the car still.
or like jim needing injectors, i could swap in a 16vT with my 01e and not have to replace it hahahahaha
but i do need an 01e slave and clutch line and shift linkage
Posted: Wed May 12, 2010 4:02 pm
by audidub
my 4k did the same thing when i got it up and running, all i did was bleed the slave and it came into it. might try that, or again if you have its a lot easier then "dropping" the tranny
Posted: Thu May 13, 2010 10:35 am
by my2000apb
audidub wrote:my 4k did the same thing when i got it up and running, all i did was bleed the slave and it came into it. might try that, or again if you have its a lot easier then "dropping" the tranny
we already bled it a few times, try again before we pull it, and if i do ill put an o1e back in with a 16vT
Posted: Thu May 13, 2010 6:28 pm
by audidub
might as well if you pull it out switch it out, not like you don't have a 4k to drive for the summer 8)
Posted: Fri May 14, 2010 11:33 am
by my2000apb
audidub wrote:might as well if you pull it out switch it out, not like you don't have a 4k to drive for the summer 8)
yeah so many decisions to make,
hmmm what to run for engine mgt?
how does the o1e work with a manual speedo?
Posted: Fri May 14, 2010 4:20 pm
by glibobbo21
same cup swap i thought?
Posted: Sun May 16, 2010 10:27 am
by my2000apb
glibobbo21 wrote:same cup swap i thought?
hmmmmm that works for the 016 locker to 016 torsen swap, as that housing came in mech and elec speedo cars, but i believe the 01e only came in elec speedo cars,
hmmm what to do about speedo signal??? :?
Posted: Sun May 16, 2010 10:39 am
by my2000apb
so it appears, after many bleedings, that my clutch slave is failing,
so do i...
pull the steering rack to get easy access to drill out the pin and swp slave cylinders
or
i have a good slave attached to a used 4k 016 box from my T-red car's swap, so i could swap out the whole gearbox and be done with it,
or
third choice
someone give me a obd2 ABA bottom end, wiring harness and ecu and ill be good to rip this JT the hell outta here and get the 16vT rolling!!!!!!
Posted: Sun May 16, 2010 1:28 pm
by bimmerboy
Why not just do the slave normally?
Posted: Sun May 16, 2010 1:36 pm
by my2000apb
bimmerboy wrote:Why not just do the slave normally?
the 4kq's slave cyl. is pinned in there, not a bolt, yeah it sucks
drill it out and replace
sounds easy, its not
Posted: Sun May 16, 2010 1:46 pm
by bimmerboy
Yea. I know. You can get a punch through the tie rod hole. It's usually not really that hard.
Posted: Sun May 16, 2010 3:19 pm
by my2000apb
bimmerboy wrote:Yea. I know. You can get a punch through the tie rod hole. It's usually not really that hard.
will the pin push out the other side?
Posted: Sun May 16, 2010 3:28 pm
by Toxcheap
Yeah it just pushes out the other side, be sure to use a roll pin punch makes it easier. Just go through tie rod hole with a long extension (as mentioned above) but what's your symptoms? because it kinda sounds clutch master related and not slave. Is the slave pissing everywhere?
Posted: Sun May 16, 2010 3:40 pm
by my2000apb
well we are going to go try and bleed it one last time, the pedal jsut doesnt want to return. even though there seemed to be extremely little air in the line
