Page 104 of 119
Re: Aarons Drag CQ: 6-8 update fail vid even LOL
Posted: Sat Jun 09, 2012 7:56 pm
by Golden91CQ
Thanks good thinkin. I just noticed your turbo is the size of your sons head :o
Posted: Sat Jun 09, 2012 8:46 pm
by speeding-g60
ya is big. here is stock 1.8T and my turbo side by side ;)
of course he was younger than now. but still.... and this one has a 5" OD inlet, this was the smaller 63mm unit i have. same hotside and CHRA though for both but thats where the likeness ends.
Posted: Sat Jun 09, 2012 10:03 pm
by TheArchitect
Half the size of that k03 is its wastegate...
Posted: Sun Jun 10, 2012 1:00 pm
by speeding-g60
and i got the clutch release valves sorted out and functional.
http://magnusmotorsports.com/products/c ... ol-device/" onclick="window.open(this.href);return false; ... ol-device/
Link to video
Re: Aarons Drag CQ: 6-10 testing clutch release valves video
Posted: Mon Jun 11, 2012 7:38 pm
by speeding-g60
i had the line lock backwards, not the needle valve. it really is non directional, it slows it down on either direction.
Posted: Mon Jun 11, 2012 8:01 pm
by 40v4kq
That really is one cool gizmo. I'm guessing its controlled with a button, and so is the line lock. So, you have two buttons you are dealing with on launch? Maybe even three with the launch controll? No wonder you talk about how difficult it is. Under all the stress of the moment I can see it being hard to get everything perfect.
Posted: Mon Jun 11, 2012 8:28 pm
by speeding-g60
nope. its rather simple. one button.
the clutch flow is thru the line lock normally, so its easy for the burnout.
then on the launch, i hold the button, and the line lock locks, and fluid is sent thru the needle valve and slowed down.
i can simplify it further by putting the button on a timer relay.
no button, burnout clutch is normal.
stage, hit the button once, and then dump the clutch to launch. no thinking about slipping the clutch, nothing but GO.
as it is now, i will have to hold the button thru the launch.
is ok..... its busy, but with more seat time i may actually get a good routine down.
Posted: Mon Jun 11, 2012 11:56 pm
by Tomis
What was the reason that you chose this actual valve? I was looking at this one, looks rather simple http://www.clutchmasters.com/custom/doc ... iagram.pdf" onclick="window.open(this.href);return false; ... iagram.pdf
Posted: Tue Jun 12, 2012 12:03 am
by vr-vagman
Tomis wrote:What was the reason that you chose this actual valve? I was looking at this one, looks rather simple http://www.clutchmasters.com/custom/doc ... iagram.pdf" onclick="window.open(this.href);return false; ... iagram.pdf" onclick="window.open(this.href);return false;
I think the CM valve will slow/limit the flow every time you press the clutch. This is not needed on higher gear shifts.
Posted: Tue Jun 12, 2012 4:00 am
by speeding-g60
a long time ago i actually did try the CM FCV-200. and did not like it. it is, like vagman said, limited on every shift. and you get three choices. and i think it still got a little bit of air inside when changing pills.
but the full adjustibility of it and also the ability to bypass. the features that i was after.
Posted: Tue Jun 12, 2012 8:57 am
by 40v4kq
So is the car ready for another trip down the track?
Posted: Tue Jun 12, 2012 10:10 am
by mr_aj_johnson
Couple of rally guys were talking about your car this weekend. You are famous.
Posted: Tue Jun 12, 2012 4:17 pm
by speeding-g60
mr_aj_johnson wrote:Couple of rally guys were talking about your car this weekend. You are famous.
haha, too funny. they were probably saying stuff like "WTF is that MORON doing going STRAIGHT? it just dont last long enough at the rate he is going!!!"
and the car is as ready as it ever is, gonna try it again in 3 days :)
Posted: Tue Jun 12, 2012 5:45 pm
by EDIGREG
nice - that valve is pretty slick.
Posted: Fri Jun 15, 2012 10:56 pm
by speeding-g60
9.81 @ 149
Posted: Sat Jun 16, 2012 7:29 am
wow :vids:
Posted: Sat Jun 16, 2012 8:44 am
by speeding-g60
finally figured out why it wasnt shifting into 3rd gear. i have a plate to stop the shifter from going into 5/6 gate. the shifter, after being rode hard for a bit, has bent that over some, and was going UNDER the plate and hitting 5th gear. there is no 5th gears on the shafts. so thats why there was "just nothing there". bent the metal around a bit, and ran a full pass.
going to be making a new plate and stiffen it up some. and now that i know the trans works good, i will be moving along with my own shifter design ;) i would show pictures, but its not done yet so i will refrain. but needless to say, it is almost time to finalize that setup!
Link to video
Re: Aarons Drag CQ: 6-15 9.81 @ 149 video is up
Posted: Sat Jun 16, 2012 9:42 am
by nismo
Glad to see you solved it. Is it worse to hit 5th, than to free rev because there's no gear there?
Eric
Posted: Sat Jun 16, 2012 12:13 pm
by speeding-g60
Eric, if it had a 5th gear set in there it would be better off than hitting an empty gate and free rev. it revved >9400 on that misshift, according to the logs. the motor is built to handle it, but still it isnt good.
if 5th were there it would still work just bog down. may even strip 5th gears teeth which then would NOT be good.
so, no 5th, and the new blockout plate is almost done now.
if you watch closely in the side view video, watching the shifter. notice at the end of the run the shifter has a hard time coming into neutral. that is because it was UNDER the plate again. gotta look/watch closely. but, its solved now. it cant happen again due to the form of the new plate.
Posted: Sat Jun 16, 2012 12:49 pm
by speeding-g60
shifter issue solved. no more missing 3rd gear.
Link to video
Posted: Sat Jun 16, 2012 4:13 pm
by speeding-g60
and the fix is in.
used to be a flat horizontal plate. not any more. now it is a vertical plate to ride against.
before.
Link to video
after
Link to video
Posted: Sun Jun 17, 2012 8:13 am
by speeding-g60
Link to video
Posted: Sun Jun 17, 2012 8:49 am
by 40v4kq
I like the video documentary of the fix. Good job Aaron.
Also, watching that shute deploy is just sooooo cool.
Posted: Thu Jun 21, 2012 9:37 am
by my2000apb
aaron thanks for the reat documentation
keep up the good work!!!!
any news on that DJM vr car?
Re:
Posted: Fri Jul 13, 2012 8:01 pm
by speeding-g60
speeding-g60 on Tue Nov 11, 2008 4:12 pm wrote:[/quote]oh, the pink motor is not as high strung as the coupe motor will be. i only take it to 8500.
for the coupe, i am looking for maybe 40psi, 10krpm, and bigger/badder shit on it. want ~750awhp or so, in that area.[/quote]
haha, i was just doing some re-reading, and look what caught my eye.
40 psi, close enough at 38psi. CHECK
10k rpm? not needed. CHECK
750 AWHP? CHECK!
weird how something i wanted 3.5 yrs ago i have today.
