Page 12 of 23
Re: Dan's 40V V8 4000 fan switch in
Posted: Tue May 29, 2012 5:54 pm
by pilihp2
Oh. That's me. 30th of June? I'll be there in the 3b'd 5k.
Posted: Tue May 29, 2012 6:21 pm
by JT4k
Sweet! Looking forward to this one.
Posted: Tue May 29, 2012 7:29 pm
by 40v4kq
Ok, sounds like we have a date settled on. June 30th it is. Mike, I will call you tomorrow evening so we can start discussing the details.
Posted: Tue May 29, 2012 7:48 pm
by JT4k
Sounds good.
Posted: Tue May 29, 2012 8:02 pm
by 40v4kq
Forgot to bring my phone home form work. Made a thread to see who is intersted.
Posted: Wed May 30, 2012 8:19 pm
by 40v4kq
Got my BBK in the mail the other day. Couldn't resist bolting up the calipers and see how they look. Correct Rotors on are on the way from AutohauseAZ.
Clears the 16" wheels no problem
Re: Dan's 40V V8 4000 BIG BRAKES
Posted: Wed May 30, 2012 8:29 pm
by 40v4kq
And before anyone points it out...I know this is the right caliper. I already had the left wheel off and thats the caliper that was closest :D
Posted: Wed May 30, 2012 9:34 pm
Nice work Dan! This is full of win!
Posted: Wed May 30, 2012 10:16 pm
Small chassis, big red brakes, white wheels, v8.
YAWN
Excuse me while I go for a nap, and hope to have half the wet dream to what it must be like in your moccasins.
Posted: Wed May 30, 2012 10:24 pm
by 40v4kq
Thanks Ben, but its only half the setup your got. LOL
PRY4SNO, you are always welcome to stop in for a ride if you just happen to be in northern california.
Posted: Wed May 30, 2012 10:25 pm
by Quattro v1.0
PRY4SNO wrote:Small chassis, big red brakes, white wheels, v8.
YAWN
*grin*
Posted: Wed May 30, 2012 11:12 pm
by JT4k
Looks great Dan.... Such an amazing car you put together. This car is inspiring to say the least.
Posted: Mon Jun 11, 2012 12:51 pm
by 40v4kq
Got around to installing the big brakes. derracuda sent down some brake line adaptors from 4kq brake master cylinders that are banjo style so I could screw those onto my existing brake lines and then bolt the banjo adaptor onto the calipers. It works but the brake lines are a little short, so eventually I need to have the proper length lines made up with the correct banjo end on one end of them.
Went from this...
to this...
and finally to this...
And boy oh boy do these work better than the A4 brakes that they replaced. The pedal is now up higher, is rock solid, and they grab probably twice as good as the A4 brakes did. I think the main reason the A4 brakes sucked so bad was the pads. I ran the cheapo pads that were in the calipers when i plucked em from pick n pull because they were brand new, but i'm sure they were some really cheap life time warrantied pad from napa or wherever so they just didnt grab very well. I looked into getting some good pads but then this brake kit popped up and i couldnt resist. They also came with a set of Porterfield Race Pads for track days.
I'm also thinkin I need to get some high temp porsche decals for the calipers because race car.
Re: Dan's 40V V8 4000 BIG BRAKES INSTALLED
Posted: Mon Jun 11, 2012 1:03 pm
by JT4k
Cool I cant wait to check these out because a BBK is next on my list. Looks very good Dan as always.
Posted: Mon Jun 11, 2012 1:07 pm
by 40v4kq
Thanks. I could have gone with standard rotors for half the price(D2 A8) but i've never had drilled rotors on a car so I figured this would be the car to have them on. Thery arent needed but just look much cooler IMHO. Just maybe i'll let you taker her for a rip.
Posted: Mon Jun 11, 2012 2:41 pm
Looks fantastic Dan!
Posted: Mon Jun 11, 2012 2:47 pm
by VWAudi4Life
40v4kq wrote:Went from this...to this...
What calipers are those? Boxster (S?)?
Posted: Mon Jun 11, 2012 2:55 pm
Looks good, stopping is also important :)
Posted: Mon Jun 11, 2012 3:00 pm
by 40v4kq
calipers are boxster. 968?
Posted: Mon Jun 11, 2012 3:39 pm
There you go :)
Posted: Mon Jun 11, 2012 5:56 pm
by PRA4WX
Looks nice! 8-) What rotors are those? Redrilled D2 A8's?
Posted: Mon Jun 11, 2012 7:25 pm
by 40v4kq
Thanks Jim. Now I can say I have parts from two famous Audi's on my car. Now if only I could get something from James Buffkin's car, like a lightbulb or a random bolt.
PRA4WX, Yeah, they are indeed redrilled D2 A8 rotors. I just went all out and went for the drilled instead of the plain ones.
And once again i'd like to iterate on how well this thing stops now. Its unbelievably better. Now the brakes are a good match for the power and the car hauls down faster when going fast down hill than it used to when going slow up hill and stomping on the brake pedal. That, and now the pedal feels like one should :-) :-) :-) :-) :-)
Next upgrade... the euro lights I got from derracuda about three months ago. Well, maybe right after I add another fan to the radiator.
Posted: Wed Jun 20, 2012 5:03 pm
by 40v4kq
Ever since this thing has been driving it has had a knocking noise in the suspension that has gotten worse over time. Both front make noise over bumps and now i'm starting to hear it from the right rear too. A little investigating and i think I found the problem/problems.
With the front end off the ground I found that I could grab the strut housing and move it in and out and it there was play between the shock and the housing. Turns out the coil over sleeve was a little too tall and not allowing the nut that holds the shock inside the tube to tighten down all the way and so the shock was actually loose inside the tube. You can see in the pic how there is no gap between the giant nut( goldish color) and the sleeve(anodized red) Both sides are like this, so I will do the same fix on both front sides.
Been rubbing pretty badly...
I cut the section off that had the worn spot on it.
Now the sleeve looks like this
I also found that the castle nut that holds the shock mount to the top of the shock was loose so I tightened that up and put it back together. Now there is plenty of space between the nut and the sleeve and no more play between the shock and the strut housing.
Now to do the driver side. I'll play with the rear later since its not anywhere near as bad as the front.
Re: Dan's 40V V8 4000 Suspension Repair
Posted: Wed Jun 20, 2012 5:23 pm
And it was free!
Good fix
Posted: Wed Jun 20, 2012 5:54 pm
by 40v4kq
ringbearer wrote:And it was free!
Good fix
LOL. Free fixes are the best.
Driver side done now too. I'm gonna go do a test drive to pick up some mexican food for dinner.
