Page 128 of 130
Re: Hanks URQ 2.6L Autopsy
Posted: Mon Jul 22, 2013 4:42 pm
by glibobbo21
Hank, dont make me fly out there for BBQ....
Posted: Thu Jul 25, 2013 8:32 pm
Oh my gosh, that Hank video is amazing. Just got to see it now. LOL. How old were you Hank?
Posted: Fri Jul 26, 2013 1:18 am
That would have been 2003, making me 18. What isn't shown in that video is that the car has 500 miles total on a basket case build that I had bought 4 weeks prior. 300 miles were accounted for on the ride a state away with Sean Mclane, and we were therefor 300 miles away from home on a fresh build that hadn't seen the road for 10 years, doing donuts on 10 year old tires. 10 years ago Sean's AAA card didn't have nearly the perks it has now! lol
Posted: Fri Jul 26, 2013 6:14 am
Hank wrote:That would have been 2003, making me 18. What isn't shown in that video is that the car has 500 miles total on a basket case build that I had bought 4 weeks prior. 300 miles were accounted for on the ride a state away with Sean Mclane, and we were therefor 300 miles away from home on a fresh build that hadn't seen the road for 10 years, doing donuts on 10 year old tires. 10 years ago Sean's AAA card didn't have nearly the perks it has now! lol
What, so you mean you wouldn't do that again?
The stuff we did when young and stu... err, I mean awesome
Posted: Sat Sep 14, 2013 3:02 pm
by PRA4WX
I'm all about stick poking threads today as i entertain the POSSIBILITY i may be able to make a day of BBQ. This one needs updates.
Posted: Tue Feb 25, 2014 1:09 pm
by Syncro16
Quite a thread to read through!
Great work and a stunning car.
I'll apologise now for going off-subject but the info I'm going to ask isn't easy to come by.
I'm looking at creating a 2.6 20V Normally Aspirated engine for my Vanagon Tristar. By this time next year, it'll be 4WD (Syncro).
It's currently running a stock late 7A apart from exhaust (early bag-o-snakes headers which then leads to a 3 inch system) and intake which has a K&N Apollo.
We have fairly easy access to 2.5TDi 5 cylinder engines over here and I'm interested in building a 2.6 20V to get a bit more torque for the heavy van.
I have been told that I can use ABF pistons and rods to bolt straight into the 2.5TDi crank and then bolt the 20V head on top.
Looking at your photos, I can see that you've modified the block in a few places to accept the 20V head and that you have a modified cambelt tensioner system, is this for a different length timing belt? Can I use the 7A crank pulley on the 2.5TDi? Which cambelt should I use? Which head studs do you use?
Lots of questions etc... thank you in advance and keep up the good work
MG
Posted: Tue Feb 25, 2014 4:05 pm
Our website has the Headbolts you will need. We use regular MLS head gaskets, with a modified tensioner system. We use 7a water pumps for added adjustability with a adjustable cam gear to help compensate for any block height issues. Yes, the 7a crank pulley can be used, we like to use the AAN TB, and the lists of modifications to the block is fairly extensive. If you shoot me an email at HankIroz at Irozmotorsport dot com, I'll send you an email with the needed modifications to make a tall deck work with a 20vt head. Be warned though, it is a pretty expensive list if you are paying somebody else to do it.
Glad to see you made it to the ProjectPad. Keep in touch.
Posted: Thu Apr 10, 2014 10:54 am
by my2000apb
did you make the custom axles with urS4/6 fronts or rears?
any tips on measuring etc for getting the length correct first try?
Posted: Thu Apr 10, 2014 11:22 am
by Syncro16
Hank wrote:Our website has the Headbolts you will need. We use regular MLS head gaskets, with a modified tensioner system. We use 7a water pumps for added adjustability with a adjustable cam gear to help compensate for any block height issues. Yes, the 7a crank pulley can be used, we like to use the AAN TB, and the lists of modifications to the block is fairly extensive. If you shoot me an email at HankIroz at Irozmotorsport dot com, I'll send you an email with the needed modifications to make a tall deck work with a 20vt head. Be warned though, it is a pretty expensive list if you are paying somebody else to do it.
I sent that email a while ago but have no reply...
Did you get the email?
MG
Posted: Mon Sep 08, 2014 11:11 pm
I heard a few cool things about this car today, people are going to want too see it at BBQ!
Posted: Tue Sep 09, 2014 12:02 am
by pilihp2
uhhh
Posted: Tue Sep 09, 2014 1:00 pm
We will see if it is done int time, but Yes, but push to get the URQ on 07k prior to BBQ in 4 weeks.
Posted: Tue Sep 09, 2014 1:23 pm
by Marc
your harness(es) are in production right now. I'll do my best to make it happen.
Posted: Tue Sep 09, 2014 1:56 pm
by jretal
how's the fender widening going?
Posted: Tue Sep 09, 2014 2:44 pm
by Mcstiff
Posted: Fri Sep 12, 2014 6:27 am
Hammer indeed!
Posted: Fri Sep 12, 2014 7:38 am
by WOMBAT
*giggle*
Posted: Fri Sep 12, 2014 9:34 am
Frick yes.
Posted: Fri Sep 12, 2014 9:50 am
by Mcstiff
I guess I need to get on instagram.
Posted: Fri Sep 12, 2014 10:14 am
by pilihp2
teeheeheeheeehee
Posted: Fri Sep 12, 2014 8:33 pm
by Colin2750
Those huge runners make me want to do ITB's on a very built N/A 07k. And then I'm like oh wait that's a lot of money for less than 400hp
Posted: Fri Sep 12, 2014 10:11 pm
That was the first thing I thought when I saw the picture, haha.
Posted: Sun Sep 14, 2014 1:15 am
by PRA4WX
About time! ;-) (Like you've had nothing to do with yourself since the stroker went the way of the buffalo) Look forward to seeing your approach to this 07K urq.
Posted: Sun Sep 14, 2014 7:08 am
by Noisy Cricket
Colin2750 wrote:Those huge runners make me want to do ITB's on a very built N/A 07k. And then I'm like oh wait that's a lot of money for less than 400hp
Yeah but you won't need a beefy clutch, or a turbo, and an 01A could handle the torque just fine, so that is a lot of expense you WON'T be spending.
And think of all the weight you would save off of the nose by not having a turbo or intercooler or beefy-ass transmission!
If it's not obvious, I really like the idea of a high strung turbo-free 07K. There are so many benefits to not having to deal with drivetrain-crushing torque or the weight and space contraints of turbo plumbing. Plus, from an aesthetics standpoint, turbos kill too much of the engine sound and tend to make them sound dull and flat. The exhaust is muffled and you don't get any intake shriek to speak of.
Posted: Sun Sep 14, 2014 10:16 am
by scubagli
Itb's and a 100 shot would probably be pretty rad...
