Page 137 of 171
Re: Loxxrider's 200 20v: :D
Posted: Sun Oct 30, 2011 10:20 am
by Mcstiff
You're just going to have to make a tubular subframe
Posted: Sun Oct 30, 2011 10:26 am
ha! Good thinking Ed. Hank, get on it! LOL
Garrett, you need to make a thread for the V8.
Posted: Sun Oct 30, 2011 10:57 am
by gtn116
Getting on that now... Have an interesting story already...
Posted: Sun Oct 30, 2011 3:32 pm
by amd is the best
I want that manifold. Seriously!
Posted: Sun Oct 30, 2011 4:28 pm
by oldsklaudidub
Posted: Mon Oct 31, 2011 5:17 pm
by EDIGREG
nice dude!! That is gonna sound MEAN
It will be another month before I get mine back on the road but it should look *something* like that
Posted: Mon Oct 31, 2011 5:30 pm
Can't wait to see that Ed. Mine probably wont be in full swing by then due to not having my IC piping done, but I hope its at least running and driving!
Posted: Tue Nov 01, 2011 1:31 pm
by k2exoman
ShavedQuattro wrote:
Holy wow, exhaust via fire hydrant...
Are you altering the exhaust all the way back?
Will the muffler you have now be too constrictive?
Your project has really come a long way!
Posted: Tue Nov 01, 2011 1:39 pm
by Mange3586
This place needs a like button. That turbo makes mine feel insufficient.
Posted: Tue Nov 01, 2011 4:53 pm
ha, valid questions.
I do plan to mate the 4" dp with my existing 3" exhaust for normal daily duties. 3" straight thru (so not really a restrictive muffler) should be pretty capable of making PLENTY of power. If need be, I'll make a cutout in the fender or just dump it straight to the ground to make max power. I don't really see the need to have 4" all the way back in the 200. Its almost impossible with the amount of ground clearance I want/need at the ride height I like. I did want 4" just in case I end up needing it in the future though.
Thanks for the comments!
Posted: Tue Nov 01, 2011 5:55 pm
by nuugen
:woowoo:
Posted: Thu Nov 03, 2011 6:46 pm
so...
It turns out Bilstein screwed up again (I think). I finally got back home today to work on the Audi. First on the list of things to do was to get her on all fours again. Opened up my box of brand new "shortened" and revalved bilsteins for the Audi and rebuilds for my dad's 328. I looked at the Bilsteins and thought, "Wow! I can't even tell they shortened these. What a great job!"
I then went out to drop them in my un-shortened strut housings, but first I dropped my nicely made spacer in the the housing so I could run the housings un-shortened until I get time to take them off and cut/weld. Then it was time to put the strut in and go merrily on my way to getting the car back together. Too bad the strut was sticking exactly 1.5" up too high for the nut hold it in the strut housing.
Apparently Bilstein shortened some other part of the strut. Maybe I don't understand what shortening the strut body means... can someone enlighten me?
Roughly 14" from top of the body to bottom.
8" from top of body to top of strut.
Can anyone compare these to stock ones? I'm thinking the "piston" part is the part that got shortened. I think this makes my suspension travel even worse
Please confirm or deny my suspicion. If this is confirmed, I am going to contact bilstein and ask for a refund. If they deny me a refund, I will just have to tell them I will never buy Bilstein again and will steer everyone I know away from them.
I had to take the freakin strut housing off to get the spacer out of it. Turned a 20 min job putting the suspension back on into a 2 hour job :curses:
On another note, I'm just glad to have the car back on all-fours for now. I can focus on getting the new turbo/manifold/dp in tomorrow and hopefully get it started! Here is how she sits now
Posted: Thu Nov 03, 2011 6:55 pm
by nuugen
If i am not mistaken they do shorten the strut tube. Or did they confirm with you that they were going to shorten the body?
Posted: Thu Nov 03, 2011 7:00 pm
by Mcstiff
They are inverted, I'm guessing they consider the yellow end the piston and the silver end the body. Sucks if that is what happened.
Posted: Thu Nov 03, 2011 7:12 pm
Yeah, thats what I'm thinking happened too. I clearly explained what I wanted done to them and why. Only problem is, I have no record of it because it was all phone conversations.
Posted: Thu Nov 03, 2011 7:42 pm
Dude that sucks! But other than that the car is looking good! I can't wait to see a video of your beast on the road again!
Posted: Thu Nov 03, 2011 8:23 pm
by Mcstiff
loxxrider wrote:Yeah, thats what I'm thinking happened too. I clearly explained what I wanted done to them and why. Only problem is, I have no record of it because it was all phone conversations.
Seems like it would be a common request! :frustrated:
Posted: Fri Nov 04, 2011 4:46 am
by WOMBAT
ugh... freakin' complications - at least your fabricator is stellar 8)
Posted: Fri Nov 04, 2011 12:35 pm
Teaser?
Only problem is my oil return line doesn't quite reach anymore. Good thing I brought extra -10 hose home
Off to make oil return line!
Posted: Fri Nov 04, 2011 12:37 pm
by Hybrid_Hatch
Sweet! this thing is going to be such a beast!!!
Posted: Fri Nov 04, 2011 12:42 pm
OK I don't really like teasers that much... here is one more
Hank,
:dur:
Posted: Fri Nov 04, 2011 12:49 pm
by death 4kqt
wow, that might make me go gay for hank too!!!!!!!
x 10000
Posted: Fri Nov 04, 2011 12:54 pm
by Hybrid_Hatch
1 fuel rail?
Posted: Fri Nov 04, 2011 1:12 pm
by VWAudi4Life
Speechless
Posted: Fri Nov 04, 2011 1:35 pm
Hybrid_Hatch wrote:1 fuel rail?
Should I have more than one?
Bad news, the oil line I brought home was a bit bigger than -10 :frustrated: the quest has now evolved into jacking some -10 from one of my friends.
