Page 148 of 171
Loxxrider's 200 20v: what to do with ps pump
Posted: Fri Apr 06, 2012 1:58 pm
by Mcstiff
You could mount it under the back seat driven off the rear diff :D
Re: Loxxrider's 200 20v: what to do with ps pump
Posted: Fri Apr 06, 2012 2:02 pm
lol good idea :D
Posted: Fri Apr 06, 2012 5:13 pm
by pkw
can you just mod the water manifold? it is less picky than the other stuff. would a forward facing throttle body design intake manifold work better than that backwards pointing one? i know you just got it, and the work is nice, but you are not married to it. You could send it back to Hank to have it reconfigured.
Posted: Fri Apr 06, 2012 5:24 pm
by crappyoldaudis
lox, you just need a v8.
Posted: Fri Apr 06, 2012 6:41 pm
I already have a V8 I could put in lol... I need some variety though ;) (the BMW is a V8)
The water manifold has already been re-modified... didn't help enough :/ A forward-facing one isn't much better in terms of space unfortunately.
Posted: Mon Apr 09, 2012 6:55 am
by my2000apb
jsut vac boost it you sisssy
Posted: Sat May 12, 2012 11:50 am
OK, I think I'm going to vac boost it. I am talking to a friend about doing all the TIG work on the IC piping and exhaust. I might have this thing running before I leave for Saudi! The way things are going right now, I may not leave until Mid-August or after (was mid-July before).
Also, because I will be out of the country for God knows how long, the car will be taken care of by a shop. Dry sump, high-rev build, here we come!
Posted: Sat May 12, 2012 11:57 am
Have you picked the shop yet?
Posted: Sat May 12, 2012 12:24 pm
I like to give my business to Mr. Swanson if I can, so EFIexpress will likely be it... if they should choose to accept the challenge :) I'm sure Marc and I will iron out some of the details at Carlisle.
Posted: Sun May 13, 2012 2:00 am
by ChrisAudi80
Winning!
Posted: Sun May 13, 2012 4:24 am
I missed out on the vac booster setup I had my eyes on. Who has one from an 80, 90, or 100?
Posted: Sun May 13, 2012 5:10 am
by RockinV8q
If you need details on the vac-assist swap you're in luck. Last week I acquired the vac equipped 200qA Cary mentioned. Drop me a line if you have any questions.
Posted: Tue May 15, 2012 2:04 pm
OK I think I have the first part of this puzzle figured out. I went to the yard today because they had an 80q. I robbed it of its MC and booster. I just want to verify that I have something that can work. At first I thought I had the wrong thing because it bolted in the 80 with 3 bolts and the 200 uses four, but then I realized it had this adapter/spacer thing on it and I think it will just bolt right on the 200 if I take that off. The pictures explain it a bit better.
I would also like to know where all the lines go. In my haste to get the thing out (junk yard was closing) I accidentally cut one of the brake lines that goes between the MC and this valve thingy. That is easily fixed, but I was hoping someone could tell me what connects to what and how I might go about adapting my stock lines to work. Assuming they are long enough, I should be able to get a brake line bender and just bend them to fit no?
Attachment ( 30852 ) : 2012-05-15 17.50.16.jpg
Attachment ( 30853 ) : 2012-05-15 17.50.28.jpg
Re: Loxxrider's 200 20v: vac assist
Posted: Tue May 15, 2012 2:15 pm
That looks like a winner! No more leaking bomb bs!!
Posted: Tue May 15, 2012 5:04 pm
by amd is the best
Man I want to ditch mine too.
Posted: Tue May 15, 2012 5:32 pm
I'll keep this thread updated so others can follow suit. It should be really easy as long as the lines don't give me much trouble.
Posted: Tue May 15, 2012 5:42 pm
by amd is the best
What about the hydraulic pump? What's the plan for the power steering?
Posted: Tue May 15, 2012 6:52 pm
That is on the back burner until I get the vac assist hooked up. However, I believe I can just use a smaller pump from a small chassis car and it shouldn't interfere with my manifold.
Posted: Thu May 17, 2012 9:35 am
by my2000apb
there shouldnt be too many unsolved lines once you swap on your master cylinder to the vac booster
Posted: Thu May 17, 2012 9:44 am
Looking good man! I can't wait to see how your car turns out, it's going to be such a total beast.
Posted: Thu May 17, 2012 10:57 am
by 123quattro
loxxrider wrote:However, I believe I can just use a smaller pump from a small chassis car and it shouldn't interfere with my manifold.
I may be doing this as well when I get my new IM from Hank.
Posted: Thu May 17, 2012 6:58 pm
I thought i.had to use the small chassis mc?
Posted: Thu May 17, 2012 7:05 pm
by yodasfro
yodasfro wrote:You'll want a pump from a V6 car as it has the correct mounting bosses for the p/s bracket. And you may need/want to use a 7A p/s pump bracket.
Posted: Sat May 19, 2012 8:43 am
by my2000apb
loxxrider wrote:I thought i.had to use the small chassis mc?
you could but dont want to, your brakes need more fluid than small chassis stuff
the t44 brake masters are bolt in upgrades for small chassis guys, so run the vac bosoter and big mc
Posted: Sun May 20, 2012 7:00 am
sweet so then i won't even need to swap lines around or anything. Guess ill get right on it when i get back home.
