Page 3 of 16
Posted: Thu Apr 29, 2010 9:20 pm
by RufCTR
If you are running the stock Motronic ECU from an S4 or S6, you can run the 034 Stage 1+ kit that I have in my 95 S6. The kit comes with the chipset, 3-bar v-map (which you already have), 36lb/hr RS2 replica injectors and a 1.9Bar WG spring. With just this and nothing else, the car should make about 300hp crank. My car has some other toys and is making 330hp crank/260whp.
As for drive-ability, it is awesome. The car feels like stock except faster. I can get 25-26mpg on the highway at about 78mph (I have a 6-spd swap). When I had the 5-spd, I was getting 23mpg on the highway. I run 93 octane Sunoco with no exceptions, but you can run the 91 octane with no issues as this is the design of the 034 chips. Good luck.
Re: Daves CQ project, the road less traveled
Posted: Wed Oct 20, 2010 1:07 pm
Man... your CQ is awesome man! I just found your thread and ya... I'd love to have one like this. Sure is a nice ride you've got yourself man!
Posted: Wed Oct 20, 2010 4:49 pm
by frostyflax17
i see one issue with getting s2 h4/h1 or rs2 headlights... they're wider than stock b3 headlights
your radiator won't work with them, did anyone else notice that?
the headlights now look good, i think you're stuck with them unless you find some 1-piece b3 headlights from europe.
good build though, smart idea to relocate the radiator to the front. what'd you do with all the space where it was? just the water-air cooler?
Posted: Wed Oct 20, 2010 5:06 pm
by seanriv
B3 headlights wont work with the B4 hood. Im sure you can get s2/rs2 b4 1 pieces to fit.
Posted: Wed Oct 20, 2010 5:21 pm
by Spike_Rally
frostyflax17 wrote:i see one issue with getting s2 h4/h1 or rs2 headlights... they're wider than stock b3 headlights
You have it the other way around, B3 lights are longer. Plus, the lights he has are B4's. I'm pretty sure B3 lights would not fit with his radiator.
Posted: Wed Oct 20, 2010 6:50 pm
by scubadave
thanks! yea this was a very enjoyable build. i love my car! ive owned this beauty for 16 years and still in love with her.
yea the rad in the front works better than i expected. once it started getting colder, the temp stays a little cooler so i may have to partially block it off. i figure once i build the ac and put a condenser in front of it, that may be just what it needed.
the rs2 headlights are designed to fit perfectly since it eliminates the corner light. im sure if you looked you would see what i mean. look at hybrid hatch's thread. he got himself a pair.
Posted: Wed Oct 20, 2010 7:02 pm
by scubadave
o yea, on the air to water is the only thing in that space. i have experienced enough heat soak to decide to change it a little bit. im thinking about moving the fluid reservoir to the rear and change the innercooler to prob double the size.
Posted: Wed Oct 27, 2010 9:52 pm
by Quattro v1.0
I got the event photos from the photographer tonight, still have some sorting to do, but here's a lil' easter egg
Posted: Wed Oct 27, 2010 10:01 pm
YUM!
Posted: Thu Oct 28, 2010 1:38 am
by scubadave
thanks ben. thats what 16 years and alot of blood ,sweat and tears, and then some love and patience put into a car will do. ive tried to sell it a few times but could never go through with it. im very glad i diddnt. if you have or find a car you love, stick with it, you will eventually get it where you want it. it took me a while to find and gather all the parts but i eventually got em.
Sean, thanks! I appreciate the pic. it really is a great example of the coupes.do you have that vid you took of my car on the dyno? id like to have it even though my motor flops around like i need to repair the snub mount this winter.
Posted: Sun Nov 28, 2010 10:46 am
by kenavery7
very nice.
Re: Daves CQ project, the road less traveled "updated"
Posted: Mon Nov 29, 2010 5:58 am
by scubadave
thanks ken.
Sooooo, all those that have been waiting for a post with progress on this car, well... I eventually did something worthy of posting.
since the trip down to vegas for the GTG I had been wanting to get the vems that almost went into my car while down there. But, I had the same problem that hybrid hatch had on his car when installing it on his car at first. (which kept him from bringing it :( )
the problem is that when you use the 7A flywheel, reference pin doesn't show up after about 2K. so the solution was discussed on his thread and I mentioned using a piece of square stock and drill a hole in it, weld the tip. Id like to say It was my idea, and maybe it was, but it was the most logical solution to the problem. Im sure thats the solution they would have come up with whether I was involved or not.
whats funny is that before I read his post I did this.
Attachment:[/quote]
[/quote]
Attachment:[/quote]
[/quote]
Attachment:[/quote]
[/quote]
Attachment:[/quote]
[/quote]
after getting this done, I saw his posting and laughed at the similarity's. but like I said, its the most logical solution.
so after doing so, I installed the vems and the 60lb injectors I got as well. had a small issue with the wbo2 wiring what we installed in vegas but was figured out very quickly. turns out one of the pins in the connector pushed back out.
so after making short work of that issue I took it for a burn and found that it has dett at higher boost even though marc says it has plenty of fuel. He mentioned that its possible that my fw mark could poss be off. So either tomorrow or after Im done with my work week, Ill double check the long skinny screwdriver in the plug hole trick and see if im advanced.
Once I have figured out the Dett issue, I will be pulling the front end off the car again and redoing a bunch of stuff that have been nagging at me in my mind. I also have a vibration that I need to get a fix on so if its not a minor problem, it looks like I may be pulling the motor and dissassembling it and having it balanced. the good; it will be balanced and I will get a set of rods for it while its apart. the bad; its going to cost a grip of money Id rather not spend feeling like I wasted it. but, it is what it is right? My car is my "Precious" and she is worth it.
thanks for readin
Posted: Mon Nov 29, 2010 8:37 am
by Dave
Nice work dave, How does it feel compared to the MTM chipset?
Posted: Mon Nov 29, 2010 8:45 am
by a_CQ
Car looks great! it just needs a set of RS2 or H1/H4 headlights.
Check your actual timing, but have you zero'd the timing through the software?
Posted: Mon Nov 29, 2010 1:50 pm
by ralleyquattro
scubadave wrote:the problem is that when you use the 7A flywheel, reference pin doesn't show up after about 2K. so the solution was discussed on his thread and I mentioned using a piece of square stock and drill a hole in it, weld the tip. Id like to say It was my idea, and maybe it was, but it was the most logical solution to the problem. Im sure thats the solution they would have come up with whether I was involved or not.
So what is the actual problem, all these CQ and 90q running out there and all are fine above 2K rpm (including my own 4kq).
Is it the Motronic?
Thanks
Posted: Mon Nov 29, 2010 2:15 pm
by quattro87
I believe the statement was made is reference to running the 7A flywheel/reference pin while using a VEMS engine management ECU.
Posted: Mon Nov 29, 2010 2:26 pm
by ralleyquattro
That's fine, but the sensor is the same so the signal should be the same... VEMS just can't see what Motronic/Hitachi can?
Posted: Mon Nov 29, 2010 2:34 pm
by Dave
no the motronic only uses it as an initial trigger. If you snap off the timing pin while driving the car will continue to run until you turn it off (ask me how i know)
Posted: Mon Nov 29, 2010 3:38 pm
by scubadave
the motronic runs the car just fine martin. it does a great job of doing so and has been for 20 years. the MTM software worked great for what it was. but compared to the vems, which is programmable, its antiquated and limited. the possibilities with the vems are endless. the mere fact that its plug and play makes it fantastic.
If I were to replace the injectors, the motronic could not run the car right. it had the stock injectors running at 100 percent DC. It needed bigger injectors in a bad way.
everyone who has replaced their stock ecu knows the benefits of having the endless posibillities of a standalone. the motronic was old school through hole tech. vems is surface mount and up to date tech. much faster processor with communication that is lightning fast.
I like it Dave. as soon as I figure out the dett issue, I will feel alot better about mashing the throttle and not worring about the engine destroying itself.
Posted: Mon Nov 29, 2010 5:05 pm
by Audilard
We need to get together sometime. I want to drive the car and see how VEMS works.
Posted: Fri Feb 18, 2011 4:44 am
by mxnhid
so i couldnt sleep...4:44am and i read the thread. What happens next??? dett issue figured out?
Posted: Fri Feb 18, 2011 5:51 am
by scubadave
so here I am brousing through the forum while at work and my project thread pops up.
yea, I believe it may be mostly handled by now. I dont get to drive the car as much lately since I dont want to drive it in the snow and road salt. not to mention god forbid it get hit by another retard that cant drive in bad conditions. the last tank of gas I had was the govt idea of a cleaner emissions fuel. they call it oxygenated fuel. just has up to 10% ethanol. not good for trying to tune for just plain 91oct. last weekend I filled up at another station I know of that doesnt have the "oxyfuel" and tiried a few full throttle pulls. after the car was warmed up completely I saw it was fueling what marc said it should. I plan on giving it another go in the next few days to see if it is corrected. Im not entirely convinced to be honest.
while I have the motor out to get balanced I had planned on sending the ecu back to marc to have him throw it in one of his cars to see if he could recreate the problem. Im not uber worried or all that impatient honestly since I dont drive the car in the winter anyway. I was hoping to get the motor done and a new clutch, new double sized atw innercooler built, tank relocated, different radiator installed, new aluminum front crossmember fabricated with reengineered snub mount, revamped suspension, volvo hybrid turbo to name a few things. but I have been a little short of funds anyway so it gets pushed until I feel comfortable I can do it financially.
I hope it turns out to be a fault with the computer as I dont understand how it could have been so difficult to tune this thing since marc has tuned so many others with this spec. I dont know, Ill cross my fingers. meanwhile Ill try to sell off some of my spare parts to try to fund this endevor. anyone want to buy an mtm chipped ecu and an 01e among other parts?
Posted: Fri Feb 18, 2011 10:16 am
by FunkWeasel
scubadave wrote:so here I am brousing through the forum while at work and my project thread pops up.
What kind of 01e and condition/etc? I could possibly be tempted. Beautiful car...I really need to look through your project thread now. :-)
Posted: Fri Feb 18, 2011 12:18 pm
by mxnhid
Those seats you installed look fantastic! I went the Volvo hybrid route, but i did some modifications to it. If it comes back to me spec'd out like i wanted, i will include it in the write up and i will let you, Dave and Bimmerboy know who did this and for how much. Right now it seems unrealistic what this guy is doing, for so little money. I love your car, it really is one of the nicest i have seen, but i think thats the Utah standard for coupes now a days. Hope you get it sorted in a decent amount of time, but it sounds like with the rebuild coming and another turbo installed, this could be going north of 400hp at the crank.
Back to those seats, were did you get them from? I want to replace mine in the wagon (i have to in order to meet spec for the 200mph run) and those actually look DD comfortable. Over 800$?
Posted: Fri Feb 18, 2011 3:25 pm
by scubadave
thank you sir. Thank you for noticing. the seats cost just over a G, but with their brackets. if I were to do it again, I would just buy the sliders and make the rest. the seat brackets were too simple to have paid what they cost me. that would save you a small chunk. and they are very nice for DD. A very nice and wise investment I might add.
North of 400 may be a bit too generous. actually Im going for somewhere between 3 and 350 at the wheels. Im not greedy and I love the fact that its a KKK turbo that is just as reliable as the k24 or 6. just better. mine is a carpet cruiser that sometimes sees a few Autox's. it depends on the surface. I do have the 90sptQ for the serious days kick'n the cones around. It is a former first place H-stock national pro solo car. but its time has come to shtcan the v6 fo a 4.2
as far as standard for Utah, dont know. although we have a nice collection in the maffia here and vegas, Ive seen some real winners if you know what I mean. I believe the Mafia just takes extra special pride in our cars. we must keep up appearances mustn't we? I have just had my car a very long time.
