Page 3 of 7
Re: Alex's CGT - 7A Swap Prep - 20v no more!
Posted: Wed Apr 15, 2015 12:53 am
by the german
looking gooooooood!
Posted: Wed Apr 15, 2015 2:17 am
Just for reference, I'm running 1g cable from the trunk of my B3 to a distribution block under the hood. After all the ground were sorted, there was negligible voltage drop. I'm using cable designed for high voltage electric motors though.
As for welding cable, the mane reason it is not a good choice is the insulation. It doesn't take kindly to oil and other chemicals. Most people that have used it saw it cracking up pretty badly after a year of 2.
Other wise, I love this project! Keep at it, should be a fun car to drive in the end.
Posted: Thu Apr 16, 2015 2:15 pm
by the german
I used these on the coupe- works great, no problem cranking the v8 off the small odyssey battery in the trunk.
http://m.harborfreight.com/6-ft-300-amp ... -8816.html
Posted: Sun Apr 19, 2015 4:03 pm
by alxdgr8
Primered and rattle canned the spots where the battery tray was ground off and some other scratches. Got rid of the surface rust spot on the hood too. Paint matched pretty well with a small test area, but with the large area it obviously doesn't. The engine bay itself is about 10 shades of white since a lot of it has yellowed, so I'm not sure there's anything I can do about it. Maybe it'll look better with the engine in it, or maybe I should spray the whole engine bay.
ImageIMG_20150418_220845638 by alxdgr8, on Flickr
ImageIMG_20150418_222256307 by alxdgr8, on Flickr
ImageIMG_20150418_231451552 by alxdgr8, on Flickr
ImageIMG_20150418_234356457 by alxdgr8, on Flickr
Posted: Sun Apr 26, 2015 3:04 am
by alxdgr8
As I was warned, it's pretty much impossible to ceramic coat the 'bag-o-snakes' header. So knowing that it was going to turn out shitty, I sprayed it extra heavy to reach all of the nooks and crannies which lead to it turning out shitty. Oh well, it'll do for now and I'm sure it'll start flaking off after a few miles.
Also hacked up the heatshield to show off the not-so-beautiful header.
ImageIMG_20150425_214513840 by Vex Art, on Flickr
ImageIMG_20150425_214439275 by Vex Art, on Flickr
Rattle canned the belt cover and I think I'm going to redo it in matte. The gloss black is just a bit too much and doesn't match the valve cover very well.
ImageIMG_20150425_214645439 by Vex Art, on Flickr
Iroz Motorsport billet goodness in the form of a power steering adapter.
ImageIMG_20150425_224830931 by Vex Art, on Flickr
More shiny parts. Decided I should try and mount the 20v AC stuff on the 20v engine in case I can get it working again. Don't have it all together yet, but I think it'll work just fine.
ImageIMG_20150425_214831301 by Vex Art, on Flickr
Difference between the B2/20v snub mount and the B3/20v snub. I'm told I need to use the 20v one to fit the chassis correctly. 20v is on top, 20v on bottom; 20v is about 1/4" longer.
ImageIMG_20150425_224638644 by Vex Art, on Flickr
Posted: Mon Apr 27, 2015 1:41 am
by alxdgr8
20v AC compressor and lines are mounted on the engine now. It's missing the lower rear bracket as the 20v doesn't fit due to the oil filter housing and the 20v one sits an inch or two too low. Should be fine with the other 3 attachment points though. If not, I'll fab up a bracket down the road.
ImageIMG_20150426_172726361 by Vex Art, on Flickr
Lines clear everything just fine. Probably going to fab up a heat shield or wrap them in fire sleeve.
ImageIMG_20150426_185028700 by Vex Art, on Flickr
20v doesn't have the mount for the AC line 'hook', but it fit perfectly at the end of the alternator adjustment bracket.
ImageIMG_20150426_185048311 by Vex Art, on Flickr
The 20v PS pump adapter doesn't allow you to run the 20v engine hook. Chopped off a small bit and drilled a new hole and it fits just fine. It's a little taller now, but hopefully it clears the hood.
ImageIMG_20150426_175448979 by Vex Art, on Flickr
Painted the PS and crank pulley so they didn't look so crusty.
ImageIMG_20150426_221513570 by Vex Art, on Flickr
Installed one side of the Jamex strut bar with Mance solid strut mounts. Looking at it now since I deleted the battery box, I could actually run a straight rod between the strut towers. This would allow me to have a much more effective strut bar than the curved Jamex piece. I might just install as is and then change it later.
ImageIMG_20150426_224951504 by Vex Art, on Flickr
Posted: Tue Apr 28, 2015 2:10 am
by alxdgr8
Got the other strut mount drilled and the brace mounted.
ImageIMG_20150427_231209726 by Vex Art, on Flickr
Also pulled the dash and heatercore in prep for the wiring.
ImageIMG_20150427_232739988 by Vex Art, on Flickr
Posted: Tue Apr 28, 2015 11:45 pm
by alxdgr8
Fresh 3B flywheel, still need to order a clutch. Also waiting on my 1.8T rear main seal to come in before this will go on.
ImageIMG_20150428_210613856 by Vex Art, on Flickr
My new toy for $100 complimentary of an Ebay auction (cosigned by my company). Sun/Snap-On DGA1000 exhaust gas analyzer. Auction listings said it had a keyboard error so I figured I might need a new one. Silly idiots didn't plug it in that's why! Plugged it in and it powers up and operates perfectly. Hell even the IR remote and printer works! Should work great for troubleshooting CIS on the Merc and for getting VEMS to pass emissions on the 90 (so I don't have to keep getting re-tested every few days until it passes).
ImageIMG_20150428_211437401 by Vex Art, on Flickr
ImageIMG_20150428_211839363 by Vex Art, on Flickr
Posted: Tue Apr 28, 2015 11:55 pm
Now that little toy will come in handy!
Posted: Wed Apr 29, 2015 11:10 am
So much jelly...
Posted: Mon May 04, 2015 12:02 am
by alxdgr8
Got both of the old wiring harnesses out, time to put the new one in!
ImageIMG_20150503_201954101 by Vex Art, on Flickr
Copper exhaust manifold nuts
ImageIMG_20150503_172830930 by Vex Art, on Flickr
New pilot bearing and 1.8t rear main seal installed (oil pan doesn't have to come off like I've seen mentioned)
ImageIMG_20150503_184517740 by Vex Art, on Flickr
New PS reservoir filter vs old one
ImageIMG_20150503_175916316 by Vex Art, on Flickr
Posted: Mon May 04, 2015 7:18 am
Nice work. I didn't have to pull the oil pan either, when I did the 7a RMS on my black coupe.
Posted: Thu May 07, 2015 12:42 am
by alxdgr8
New engine harness is routed through the firewall (what a pain!). Also found some cracking around the clutch master cylinder, going to order the firewall brace from 034. Still working on figuring out where everything hooks up and what isn't used.
ImageIMG_20150506_215424059 by Vex Art, on Flickr
New clutch master and slave
ImageIMG_20150506_220748271 by Vex Art, on Flickr
Didn't like the gloss black on the timing belt cover, so I redid it in a gunmetal. PS pump cover and fuel rail are done in the same.
ImageIMG_20150506_214941497 by Vex Art, on Flickr
With the 093 trans, you have to modify the bellhousing to accept the timing/reference sensors. The 016 trans in 4kq apparently has this, but not the 093 on the CGT. Easy fix with the angle grinder.
ImageIMG_20150506_172916172 by Vex Art, on Flickr
Clearanced
ImageIMG_20150506_175821700 by Vex Art, on Flickr
Sensor clear just fine
ImageIMG_20150506_175955783 by Vex Art, on Flickr
The horror of trying to integrate two different wiring harnesses. I may be overdoing it trying to get all of the dash warning lights to still function. The wiper motor and spray pump definitely need integrated, possibly more.
ImageIMG_20150505_230029368 by Vex Art, on Flickr
Posted: Thu May 07, 2015 6:50 pm
by the german
Loving it! It's going to be worth it when it's all done and everything works like it should.
Posted: Thu May 14, 2015 12:11 am
by alxdgr8
Painted the fuel rail and the timing cover in a gunmetal that looks much nicer than the gloss black.
ImageIMG_20150509_202630235 by Vex Art, on Flickr
ImageIMG_20150509_202212132 by Vex Art, on Flickr
New clutch. Ordered a Luk for a 200 20v on the recommendation that it was just a rebadged Sach for $100 less. Looks like the clutch disc is indeed Sachs, but the pressure plate is Luk. Still should do the job just nicely. Had to use the Coupe GT throwout bearing due to the differences in the transmissions. The CGT TOB is slighly different from the AWD 016 trans TOB, but it should work. The 016 version has a slight cup in the mating surface, but it's also plastic where the CGT one is metal.
ImageIMG_20150512_205438072 by Vex Art, on Flickr
ImageIMG_20150512_190503982 by Vex Art, on Flickr
ImageIMG_20150512_201342087 by Vex Art, on Flickr
by alxdgr8
And some fun with work lights and a dark garage
ImageP1010088 by Vex Art, on Flickr
Posted: Thu May 14, 2015 12:21 am
by the german
If you make the engine bay any nicer you are going to have to strip and repaint the rest of the car to match ;)
Posted: Thu May 14, 2015 12:47 am
by alxdgr8
Don't give me any ideas!
Posted: Mon May 18, 2015 12:53 am
by alxdgr8
Box of goodies from Hersh Performance and Racing. Poly engine/trans/subframe mounts.
ImageIMG_20150517_183243166 by Vex Art, on Flickr
Engine mounts are in
ImageIMG_20150517_202528850 by Vex Art, on Flickr
Trans mount
ImageIMG_20150517_202519332 by Vex Art, on Flickr
034 firewall brace to stop the cracking
ImageIMG_20150517_183049273 by Vex Art, on Flickr
Installed
ImageIMG_20150517_191500316 by Vex Art, on Flickr
And the engine is in!
ImageIMG_20150517_210318423 by Vex Art, on Flickr
Need a 20v throttle cable as the 20v one is too long
ImageIMG_20150517_210448012 by Vex Art, on Flickr
Posted: Mon May 18, 2015 8:29 am
Whoa, this is the first time I've looked through this. Super clean! Excellent work
Posted: Mon May 18, 2015 9:42 am
by 40v4kq
Yeah, great job for sure Alex! My only gripe (and its a small one lol) is that oil filler cap. I had one of those and it leaked like crazy, it was horrible. Do yourself a big favor and get a proper black plastic cap (autohauseAZ has them) and keep that Purdy engine clean :)
Posted: Mon May 18, 2015 2:32 pm
by alxdgr8
40v4kq wrote:Yeah, great job for sure Alex! My only gripe (and its a small one lol) is that oil filler cap. I had one of those and it leaked like crazy, it was horrible. Do yourself a big favor and get a proper black plastic cap (autohauseAZ has them) and keep that Purdy engine clean :)
Thanks for the heads up, I think I have a few plastic ones sitting around that I'll throw on.
Posted: Mon May 18, 2015 2:35 pm
by alxdgr8
My plans to retrofit the 20v AC system have been thwarted after reading the R134a conversion TSB. The 20v uses a York compressor which can't be converted, therefore I'll have to use the 20v one (a Denso). Need to find some B3 AC lines then since they are different and then convert the compressor o-rings and accumulator/drier. But that'll be done down the road, more important things right now than AC!
Posted: Mon May 18, 2015 7:06 pm
by the german
Woohoo!! Getting close. Gotta get it finished up so you can cruise around now that it's nice out :)
Posted: Mon May 18, 2015 9:17 pm
I'm in the process of moving all my hoarded Audi parts to my new home.
When I do so, any spare AC/7A parts are yours for the picking if you like.
I'll even be in Seattle come late August... nothing beats free parts, delivered free!
