Page 26 of 34
Posted: Sat Apr 12, 2008 11:58 am
by cuatrokoop
Wizard-of-OD wrote:Both will do the same Job fergie.
Not quite. One would be a shear panel, the other would be put in compression/tension depending on load. Plus, he'd have the plate covering up an existing weld if it were on the bottom. He could inset a piece of plate in the open end and TIG it in place and not worry about welding over top of welds (bad) or having the plate cover a weld (bad).
Regardless, Derek knows how to do things and I don't like picking nits on his work.
Posted: Fri Apr 25, 2008 10:40 am
by derracuda
time for some more updatin'...
i got a big order of parts in for the suspension. 1.25- 1.20wall DOM tubing, all chromoly rod ends.... 3/4" heim joints for the ball joints, rated at 28k lbs...
and 5/8-3/4" heims for the inner control arm pivots rated at 42k lbs (more material in the head makes it stronger. i also got 3/4" adjusters for the inner control arms... these will allow me to fine tune track width and wheel base as well as castor/camber.
and for my new upper front strut mounts, i got some 3/4" spherical bearings and had some plates made to hold them. i'll be drilling the holes in them yet as i didn't want to pay for something i could to myself. these will mount under my new steel upper strut tower mounting plates.... all adjustable of course.
i'm hoping to have some control arms built this week as well as both my subframes and upper strut mount plates. then all i need are my new strut inserts and then i can really get cookin here
Posted: Fri Apr 25, 2008 11:53 am
by derrish_vulf
Posted: Sat Apr 26, 2008 8:11 pm
by derracuda
ok,... upper strut mounts...
and camber/castor plates. all i'm after is castor, so they plates only allow for fore/aft adjustments.
Posted: Sat Apr 26, 2008 8:36 pm
by Hybrid_Hatch
as always, amazing work that i'm envious of... *golf clap *
Posted: Sat Apr 26, 2008 8:38 pm
by s2 on the way
so we finished project oem, now onto as f-in custom as you can possibly get....
flippin redundiculous....
and next comes the pre made 10 in wide 4k kit...."boy I sure like 4k's, especially if I can have 10 in rollers with no bodywork
Posted: Sat Apr 26, 2008 9:13 pm
by derracuda
thanks!
i was working on the control arm setup, but i first need to know where the strut and wheel is going to sit to get my everything down perfect..... i'm running into a tight setup angles wise with the new "ball joint" rod ends.
ok, control arms.... what i've covered so far...
i just need something like this... adjustable, simple right?.. mmmm, wrong...
first up, the lower ball joint needs a way to attach to the spindle... so this was my solution... 3/4" fine thread bolt = 19mm shank and fits just right into the old ball joint shaft hole...
grade 8 bolt and i don't want to change the heat tempering of the bolt, so i cut it with a hack saw... kinda time consuming, but oh well..
you don't want stress causing rough area's in a high stress bolt, so i used a sanding disc wheel to carefully smooth it down real nice
then there's the little notch needed for the through bolt of the spindle... carefully notched that out with a carbide bit
BAM... in place nice and snug
next up there needs to be a spacer to allow the rod end to get full articulation
the large washer is a safety washer incase the joint-ball itself fails... it can't slide past the larger washer. i figure if the sucker breaks off, i got other problems to worry about first
now that the outer joint attachment is out of the way, time to locate the inners on a jig..
and part of my jig to hold the outer "ball joint"..
now comes the tricky part and i don't blame you if your eye glaze over like 5 times, because mine did that all yesterday evening trying to get this all figured out...lol
here's part of the head scratchin' fun...
the inners rod ends are 3/4 shank, 5/8 bore hole, and has 32 degrees of total articulation mounted sideways (which is how i plan to mount them in the car) and with a 13.5" long control arm, i have 5.75" of total travel at the end...
next, the outer rod ends are 3/4 shank. 3/4 bore hole and have only 26 degrees of articulation, and with the control arm length of 13.5" gives me just under 5.75" of travel on the long end.
the struts i'm going to use have 5.6" of total travel... so i have to plan very carefully for the positioning of my rod ends so that i don't have binding...
furthermore, to compound this angular circus, the stock ball joint hole in the bottom of the spindle is canted at 13 degrees the wrong way.. so, what that means, is that with the inner mounting points being higher in location for my geometry to stay in a range i want, the outer rod end needs to point downward at 13degrees, and then have the inner mounts and tubes intersect at odd angles that i don't feel so comfortable with in terms of strength... so i'm still thinking the control arm situation over while i get the upper strut mounts positioned, find out just where the new lower ball joint position will be (remember with the top of the strut tilted back, the bottom needs to go forward to keep the wheel centered in the wheel well.
time for bed tonight.. blah.
Posted: Sat Apr 26, 2008 9:37 pm
by Wizard-of-OD
:woowoo:
Amazing work Derek!
Posted: Sun Apr 27, 2008 7:57 am
by PRA4WX
No wonder you were ready to go to bed!
Posted: Sun Apr 27, 2008 9:34 pm
by derracuda
annnd today's progress...
mostly self explainitory
whoops!
and the good news is that it looks like i won't have the cut into the underside of the hood as i made the plate as confined as i could. hopefully i'll have some more tomorrow... depends on the regular work load.
Posted: Sun Apr 27, 2008 9:51 pm
by s2 on the way
so the upper mounts are for the caster, and then you can control the camber with the lower a arms little adjusters right?
and then from strut to hub carrier, the little adapter plate you are using, are you going to mount the carrier side with two bolts and then the strut side with just one bolt so it can move a bit?--or maybe not strong enough, or too much camber under spring compression?
or are you just going to remake the spacer/ plates with the correct bolting to bolt all 4 bolts and utilize your ideal camber and adapt it to the new angle of the strut?
sorry for the dumb questions, just trying to rationalize all the creativeness
Posted: Sun Apr 27, 2008 10:01 pm
by derracuda
the strut-spindle extension will be a lot more than just a little plate.. the little plate was just for mockup purposes. once the upper strut plates are in, then i can just about finalize the strut-spindle adapter... and i do plan to incorporate an adjustment into that for the camber.
Posted: Mon Apr 28, 2008 6:43 am
by s2 on the way
ah ha, more than meets the eye
Posted: Mon Apr 28, 2008 7:10 am
by Audilard
Yep, again, Derek does nice work!!!
Posted: Mon Apr 28, 2008 7:24 am
by WAUG0806
8) tasty looking ingredients!
Please make 2 sets of each!
did you slip the new stut top "box" down inside the original sheet metal to hit both layers or will they be welded on the top?
Posted: Mon Apr 28, 2008 8:01 am
by derracuda
thanks Darin
WAUG0806 wrote:8) tasty looking ingredients!
it will go down to both levels and i also have some additional strengthening plans that i can only show with pics... so wait for those
Posted: Mon Apr 28, 2008 9:40 am
by mjlangley
Derek-
Any reason that you can't fab your LCA's so that the heims on the inner end are at 90 deg. from the mount bolt? This would allow easier camber adj., as you don't have to adjust the spacers on the bolt when you change the arm length.
-MAtt
Posted: Mon Apr 28, 2008 10:22 am
by derracuda
mjlangley wrote:Derek-
-MAtt
it has to do with space constraints.... the adjusters i have won't allow for that because of the lengths of everything involved.... i get something figured
Posted: Mon Apr 28, 2008 11:51 am
by derracuda
i just saw this pic in RScoupe's thread...
.. wow that looks tough.. anyone have any info on it?
Posted: Mon Apr 28, 2008 11:53 am
by Audilard
There used to be a website out there somewhere show how he cut and welded these M3 or M5 fenders onto the coupe. I don't know where it is.
Posted: Mon Apr 28, 2008 8:44 pm
by derracuda
finished up the boxes tonight...
Posted: Mon Apr 28, 2008 8:50 pm
by oldsklaudidub
so Derek what kind of steel am I looking at here. it looking real nice. :bump:
Posted: Mon Apr 28, 2008 8:51 pm
by derracuda
you're lookin at the finest grade 3/16" mild steel from the scrap pile here in the shop
Posted: Mon Apr 28, 2008 8:57 pm
by Matt
I'm kinda worried about the pieces that are between the bolts and where the strut bearing sits. They look awfully thin. I suppose the block that holds the upper bearing is nearly the full width of the box though...
by oldsklaudidub
any disign for a tower brace?
