Page 4 of 17
Re: 24v vr6T CQ Project: EATSGTR, epic page 1 pic UPLOAD!!!
Posted: Thu Jun 23, 2011 8:44 am
by my2000apb
Highlander wrote:This is going to be a good one. My favorite kind of build........HARD CORE for sure.
Craig Cook
yes sir nothing but hardcore here, no more street vs track compromise!!!
ShavedQuattro wrote:Gonna be a ripper
thanks, fuel rails are perfect, spacing is almost there
sent you a PM re:injectors
fasterthenrs2 wrote:nice project me like
thanks, theres going to be some fun cq days @ NED coming up
Posted: Thu Jun 23, 2011 9:08 am
my2000apb wrote:audifreakjim wrote::bump:
does jimmy wnat an update?:)
ive got some juicy pics
YES! I am slacking on my project, so let's get some pics
Posted: Thu Jun 23, 2011 9:19 am
by my2000apb
Posted: Thu Jun 23, 2011 9:26 am
by my2000apb
Posted: Mon Jun 27, 2011 2:06 pm
by my2000apb
UPDATE: intake manifold work has begun!!!
IM from head to TB
-034 MS r32 headflange, cnc’d for perfect transitions from ross oval tubing to rectangular r32 ports
http://www.034motorsport.com/engine-com ... 18162.html
- HS tuning, r32 intake manifold gaskets, cant use oem o-rings,
http://www.hstuning.com/home/tt-mkii-20 ... old-gasket
-034 MS r32 phenolic spacer
http://www.034motorsport.com/engine-com ... 19672.html
- Ross Machine Racing , oval runner
http://www.rossmachineracing.com/ovaltube.html
velocity stacks
http://www.rossmachineracing.com/ovalstack.html
and plenum flange
http://www.rossmachineracing.com/univer ... plate.html
- Sharpe Products, plenum material, 6” diameter 6061 0.1875” wall and 6” dia. Hemispheres.
That’s as much as you get to know for now, the feed from TB to plenum is just about dialed, ill get some pics snapped of how that will lay out. There will be very even cylinder distribution
So we’ve got the head flange finished from porting/polishing and is ready for runner welding. The oval runners have been cut to length, now just to make them dead flat with the Bridgeport. The plenum and hemisphere/plenum caps have also been cut. On to the PICS!!!!
Re: 24v vr6T CQ Project: EATSGTR, sexy intake mani parts!!!
Posted: Mon Jun 27, 2011 2:12 pm
by my2000apb
Posted: Mon Jun 27, 2011 3:09 pm
That is more like it
Looks great!
Posted: Mon Jun 27, 2011 3:11 pm
by Highlander
Damn,
this is going to be cool........totally motivates me to take my car to the next level.
Brilliant.
Cheers,
Craig
Posted: Mon Jun 27, 2011 5:38 pm
by ChrisAudi80
Good work Tim. Why are the stack even? Are the runners not unequal length?
Posted: Tue Jun 28, 2011 5:47 am
by Lord_Verminaard
Unlike the early 12v VR's, which had unequal lengths in the manifold to make up for the head runners being different, the 24v's have same-length runners in the intake and the difference is made up in cam phasing- IE. the rear cam has a slightly different profile than the front.
Brendan
Posted: Tue Jun 28, 2011 6:24 am
by my2000apb
ChrisAudi80 wrote:Good work Tim. Why are the stack even? Are the runners not unequal length?
cam compensation in the 24v's
Lord_Verminaard wrote:Unlike the early 12v VR's, which had unequal lengths in the manifold to make up for the head runners being different, the 24v's have same-length runners in the intake and the difference is made up in cam phasing- IE. the rear cam has a slightly different profile than the front.
Brendan
also if you look at some of the pics, you can see where the plenum and flange meet, theres about ~1/2" before we'd run into the coolant res area
because the VR motor is upright vs a 7a where its leaned to the pass side, theres less IM room, so a lot is packaging, and the cam compensation is there, and its not the main reason, but theres been plenti of power made with this style IM
Posted: Tue Jun 28, 2011 7:56 pm
by ChrisAudi80
my2000apb wrote:ChrisAudi80 wrote:Good work Tim. Why are the stack even? Are the runners not unequal length?
Brendan
Aha, I see. I guess going turbo, the motor would not be as sensitive to the unequal length runners.
Really looking forward to see your IM. I dig sexy IMs
Posted: Wed Jun 29, 2011 6:53 am
by vr-vagman
[quote="ChrisAudi80 ... Aha, I see. I guess going turbo, the motor would not be as sensitive to the unequal length runners.
[/quote]
Not quite true Chris. IMHO what is important for N/A motor (in terms of IM) the same is for SC one. The N/A motor is also "boosted" with atmo pressure.
Posted: Wed Jun 29, 2011 7:27 am
by my2000apb
vr-vagman wrote:[quote="ChrisAudi80 ... Aha, I see. I guess going turbo, the motor would not be as sensitive to the unequal length runners.
[/quote]
there isnt a sensitivity issue with the unequal runner lengths, the cam compensation / durations, allow the banks to get equal amounts of AIR, air at combustion chamber opening, which is much more important to have equal than the distance the air is traveling.
its the equal available air supply per cylinder, whether it be runner length, or a form of compensation to vary cylinder bank airflow, the banks ahve the same amount of available air
Posted: Wed Jun 29, 2011 10:33 am
by vr-vagman
I thought Chris is talking about AAA engine with equal lenght runners, i.e. so called SRI.
Posted: Wed Jun 29, 2011 5:33 pm
by ChrisAudi80
vr-vagman wrote:I thought Chris is talking about AAA engine with equal lenght runners, i.e. so called SRI.
Short Runner Intake? This engine is the 24v, Ivo.
Posted: Thu Jul 07, 2011 2:11 pm
by my2000apb
ChrisAudi80 wrote:vr-vagman wrote:I thought Chris is talking about AAA engine with equal lenght runners, i.e. so called SRI.
24v yes
runners are still unequal, cams compensate
no major updates on this one, mostly me jsut tryign to figure out how to plumb all the coolant and oil, as the motor being mounted sideways makes it a bit harder.
one of my summer jobs fell through, so im raising some funds to pay a debt before i continue getting any more parts on this thing.
buy some parts
http://www.motorgeek.com/viewtopic.php?f=4&t=41551" onclick="window.open(this.href);return false;
Posted: Thu Jul 14, 2011 11:44 am
by my2000apb
ok, mini update
ill be dropping off my cylinder head @ ryans to get part of my IM welded up, from the head flange to plenum flange then we can put it back in car for a few
also i need to get my 034 24v vr6 exhaust flange machined, it wont even fit over the exhaust studs :curses: :frustrated:
so ill be getting the number 2 and 4 cylinder holes enlarged just a tad so the studs fit through them, and then enlarging the other cylinder mounting holes so that the manifold can expand. the flange is currently a single piece, i will be cutting it between 3 and 4 cylinder holes, so each piece is centered on its middle of three cylinders and allowed to expand under heat
i cashed in a few amazon credit card points and have 16an turbo drain weldon coming, a few small npt adapters and what i believe is the correct metric adapter for the holset oil drain
Posted: Fri Jul 15, 2011 12:37 am
by R90Q
super
Posted: Sun Jul 24, 2011 12:10 pm
by bdcoombs
awesome work.. thanks for sharing..
Posted: Wed Aug 03, 2011 6:01 pm
by audidub
hmm i know i finally worked on your intake where's the update?
Posted: Fri Aug 05, 2011 10:32 am
by my2000apb
Well dang this is my 8000th post, damn
Ok well seems like a good time for an update
Ryan @ Higbee Fab. and myself finally got some time to get some more intake manifold work done. Since the last update ryan has finish welded the velocity stacks to the plenum plate above and below. We were initially going to just weld the back side of the velocity stacks, but as he has a mill, he welded the inner plenum side of the plate/stacks as well. Once that was all done, he had it pressed to dead flat and then we went and machined it flat and clean for the inside of the plenum. There are a few small pits but they will be filled and cleaned when we get back into it for plenum and TB feed welding.
We are using full hemispheres to enclose the plenum ends rather than rounded end caps, the ports on the VR are pretty close to each other. Soo close that if you look at the last update’s pics you can see the velocity stacks come about 1mm from interfering with each other. I wanted the #1 and #6 cylinders to have air equal to that of the other cylinders, so the larger hemispheres give the end cylinders the same volume to draw from as the others. Ryan milled the plenum plate nice and round in prep for hemisphere welding.
I got the head and IM lower back and its now in the car and has the endcaps and plenum clamped on, so we can continue work in the engine bay while knowing exactly what area is taken up by the IM.
the plenum has been cut and prepped for welding, fitment is almost perfect, we wont be welding it until it is perfect. endcaps are almost done as well, but we will be fitting the TB to plenum feed before anything above the plenum base is welded
On to the pics!!
Posted: Fri Aug 05, 2011 11:00 am
by death 4kqt
sex
Posted: Fri Aug 05, 2011 11:18 am
by my2000apb
death 4kqt wrote:[/quote]sex[/quote]
yea i agree
and ill give ya a sneak peak on next update
Posted: Fri Aug 05, 2011 11:25 am
by death 4kqt
header porn is the best
