Page 34 of 49
Re: Casey's 200 20v: IT RUNS!!!WOOOO!!!!
Posted: Thu Aug 23, 2012 4:44 am
by death 4kqt
sounds mean, its going to sound evil with boostage.
Posted: Thu Aug 23, 2012 5:15 am
by groff
WOMBAT wrote:Never mind what is still left to do. IT RUNS!!
seeeeeee, glad you finally adopted my mentality now!
Posted: Thu Aug 23, 2012 5:20 am
by death 4kqt
Thats how i do it, ive started engines with no exhaust manifolds etc.... i started up a virago 1000 motor that i just rebuilt the other day on the floor..couldnt wait to get it in the bike...
Posted: Thu Aug 23, 2012 5:29 am
by groff
death 4kqt wrote:[/quote]
Thats how i do it, ive started engines with no exhaust manifolds etc.... i started up a virago 1000 motor that i just rebuilt the other day on the floor..couldnt wait to get it in the bike...[/quote]
damn near did a compression test on the engine stand in my dining room last month by cranking it over off the truck battery, but decided against that after seeing the junk accumlated in the cylinder head
Posted: Thu Aug 23, 2012 9:41 am
by WOMBAT
My turbo oil feel leaks between the center section and the brass NPT adapter.
Teflon tape or crush washers?
Posted: Thu Aug 23, 2012 9:43 am
by WOMBAT
death 4kqt wrote:[/quote]sounds mean, its going to sound evil with boostage.[/quote]
Hell yes it will!
Did you use the stainless steel universal coolant hoses on your car? If so, are they worth it?
Posted: Thu Aug 23, 2012 10:01 am
by groff
WOMBAT wrote:My turbo oil feel leaks between the center section and the brass NPT adapter.
tape until a new JEGSSSSSSSSSSSSSS fitting arrives that isn't brass
Posted: Thu Aug 23, 2012 10:02 am
by my2000apb
tape and crank it tighter
Posted: Thu Aug 23, 2012 10:03 am
by death 4kqt
Hell yes it will!
Did you use the stainless steel universal coolant hoses on your car? If so, are they worth it?[/quote]
I used it, and it works, but i don't really like it. I don't really have any choice without some major reworking, so that is why I used it. It has served its purpose, so i guess I am satisfied with it.
Posted: Thu Aug 23, 2012 10:09 am
by WOMBAT
Yea I might have to use them. The car has 1.25" I/O and the radiator has 1.5" and 1.75" I/O
Posted: Thu Aug 23, 2012 10:13 am
by my2000apb
lots of oem rad hoses have small flare/transitions on the ends
or another option
im making 1.25" mandrel alu water pipes for my 16vt 4kq, and using 1.25>1.0" reducer elbows off the block connections and 1.25" straight silicone hump hoses to connect to the b3 80 radiator
by death 4kqt
can you have the outlets of the radiator reworked with sizes and locations that would allow stock type hoses? I always find myself wishing my car could run all stock hoses.
Posted: Thu Aug 23, 2012 6:30 pm
by WOMBAT
I lucked out. Went to Advance Auto with some bent up coat hangers and a tape measure and ended up with some decent radiator hoses!
Before: only used the two larger hoses
After:
Installed:
Good to go!
Posted: Thu Aug 23, 2012 6:34 pm
by my2000apb
get some non perforated clamps on those!
Posted: Thu Aug 23, 2012 6:45 pm
by WOMBAT
Oh hush, you
Posted: Fri Aug 24, 2012 4:42 am
by groff
needs moar bling to be a show car!
Posted: Fri Aug 24, 2012 7:15 am
by Rallyfreak202
Hell yeah Casey! Nice stuff man.
Posted: Fri Aug 24, 2012 7:42 am
by WOMBAT
I drove it a blistering 15mph this morning around my block! Never been so excited to drive so slow haha - it felt great! Also realized I hadn't filled my hydraulic system yet, oops.
Posted: Sat Aug 25, 2012 9:26 am
by WOMBAT
Filled the hydro system and that's all well and good. It sounded like I had air in the ps pump but it turns out it was my distributor rattling... That can't be good for timing accuracy. Can dizzys be rebuilt?
by WOMBAT
Posted: Sat Aug 25, 2012 10:05 am
by my2000apb
yes, can be rebuilt
Posted: Sat Aug 25, 2012 11:26 am
by WOMBAT
Is that a DIY item or send out for rebuild kind of thing
Posted: Sat Aug 25, 2012 11:36 am
by yodasfro
Depends on what version of the distributor you have and what parts you intend on replacing? Do you have a metal gear or stock plastic?
Posted: Sat Aug 25, 2012 12:01 pm
by WOMBAT
Metal gear - not sure if it's a matter of shimming or if the bearings have play
Posted: Sat Aug 25, 2012 12:15 pm
by yodasfro
Shims there are no bearings.
