Quit showing off the KWs already and get this back on the road!
Darin's 80q…Alive...
Re: Darin's 80tq...255's...
Is it done yet?
I gotta say, I will be a bit jealous of all that rubber when you are rolling again. Nice!!
Re: Darin's 80tq...fuel line fittings...
You could gain another couple millimeters if you switch to heim joint tie rods.Audilard wrote:
Mark Siggelkow
'90 CQ-R - NASA GTS-4
'12 TT-RS (Wife's DD)
'00 A4 1.8TQ (My DD)
'62 356B (vintage racer)
They look aggressive and are cheap enough, but i dislike the 615's a fair amount. Poor performing tire for me.Audilard wrote:More pointless pics of my car. I'm really liking these gunmetal wheels on the black car with the s4 skirt. It's really going to look good with the upper door trim removed, B4 rears and fresh paint....
RS2 mirrors would be sweet too..
....and 255's. Here are the fronts with the 235 track tires and a 10mm spacer:
Those 235/40's are more like a 245, so what's another 10mm?I can get the fronts to work...
I think I'll sell my other ABT's with the 235/40 Dunlop Star Specs. 17x8 25mm offset. Gotta buy some Azenis!!
The 245/40/17 tire is quickly becoming irrelevant in the tire market. There are fewer and fewer options out there for that size. The best tire in that size was the Dunlop Direzza Star Specs, which Dunlop is no longer making. Those are what I really want, but won't be able to find that tire anymore. I can't find anything really comparable. Here is that tire on my wheels in 245/40/17.
245/40/17 options:
Toyo Proxes R1R
Ventus R-S3
Potenza RE-11
Opinions?
Toyo Proxes R1R
Ventus R-S3
Potenza RE-11
Opinions?
Where did you get the info the direzza is discontinued? I am gonna keep my tirerack eyes peeled for when those go on clearance. There are still lots of 245-40-17 tires though, far more than 255-40-17s. I really liked the hankook v12s. Awesome budget tire, and 255-40-17s fit well on 8" wide wheels. The direzzas in 255s are too wide for a 8 wide imo.
those direzzas seem to run a size wide all arouynd
24v-VR6T-CQ BEAST http://www.theprojectpad.com/viewtopic. ... 193#p37887
16v-ABA-T VEMS O1E ETC 4Kq http://www.theprojectpad.com/viewtopic. ... 201#p38264
Tirerack already lists them as discontinued and you can't find that tire in 245 anymore.ShavedQuattro wrote:Where did you get the info the direzza is discontinued? I am gonna keep my tirerack eyes peeled for when those go on clearance. There are still lots of 245-40-17 tires though, far more than 255-40-17s. I really liked the hankook v12s. Awesome budget tire, and 255-40-17s fit well on 8" wide wheels. The direzzas in 255s are too wide for a 8 wide imo.
I just went to two EVCOs and they weren't any help. The only -6 fittings they had were brass with yellow caps. Guess I'll order from Summit.
I like the HTRZIII, cheap, good treadwear.
http://www.tirerack.com/tires/tires.jsp ... &tab=Sizes" onclick="window.open(this.href);return false; ... &tab=Sizes
savagerocco
Is this thing running yet?
Mentosman42
I second the v12's. Got a set from tirerack with a $80 or $100 rebate a while back, great bang for your buck.ShavedQuattro wrote:Where did you get the info the direzza is discontinued? I am gonna keep my tirerack eyes peeled for when those go on clearance. There are still lots of 245-40-17 tires though, far more than 255-40-17s. I really liked the hankook v12s. Awesome budget tire, and 255-40-17s fit well on 8" wide wheels. The direzzas in 255s are too wide for a 8 wide imo.
95.5 ur-S6
83 20vt urQ
83 20vt urQ
:stupid:savagerocco wrote:Is this thing running yet?
mrmotorhead13
FWIW I have RS3's on the track Miata and they're great. Stick well and wear well both.
Re: Darin's 80tq...no fuel...
Got it all together and went to start it. It cranks over just fine, but the fuel lines aren't pressurizing. After some cranking I check the fuel rail lines and there is not fuel in the line.
Won't run without gas!!
Might wanna look at the pump. Going lean at WOT would explain a lot. Jump it with 12v and see if it runs
Good news. Got it fired up. Bad news. It's blowing white smoke like a locomotive.
savagerocco
Re: Darin's 80tq...fired up, but...
Blown head gaskets always smoke until you get the coolant burned out of the exhaust
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
death 4kqt
Darin, did it smoke right away after starting, or after running a bit and getting some heat in the exhaust? If the latter, then it its probably just coolant from you prior mishap burning off, as Brent said. I had the latter happen after a headgasket issue on my 3b 90.
It got more smoke as it warmed up and I let it run for a while at about 3k rpms. It has tapered off significantly so I hope it's just about all burnt off.
Panic! Nevermind. Whew..
I'm sure it'll be fine
glad you had some wrench time, especially this close to Christmas!
Speaking of white smoke behind cars, mine did that the other day... :(
Did the smoke smell like rubber?
