k26 compressor housing bolts
Posted: Sat Mar 21, 2015 5:19 pm
Does anyone know what size spline drive I need for the 4 bolts holding the compressor housing backing plate to the center section? I need to order one, and don't want to order the wrong one.
Thanks
Re: k26 compressor housing bolts
Posted: Sun Mar 22, 2015 1:18 pm
by Dutchbroracer
DE80q wrote:Does anyone know what size spline drive I need for the 4 bolts holding the compressor housing backing plate to the center section? I need to order one, and don't want to order the wrong one.
Thanks
Are you talking about what size torx bit to use?
Posted: Sun Mar 22, 2015 1:33 pm
Is that what its supposed to be? None of the torx bits I have seem to fit it. The one that is close is pretty sloppy in the wide slots.
Posted: Sun Mar 22, 2015 1:51 pm
by yodasfro
The bolt heads appear to say RIBE which would indicate that they are ribe drive bolts. So you need a set of ribe drive sockets.
Posted: Sun Mar 22, 2015 1:54 pm
Thanks Austin. I'll see what I can find.
Posted: Sun Mar 22, 2015 7:50 pm
by Dutchbroracer
DE80q wrote:Thanks Austin. I'll see what I can find.
Yeah I don't know the exact name, I'll check tmw at work. Napa auto parts had the whole set for like $40 bucks. They are extremely tight, I had to use a torch to get them off.
I think the brand is called Carlyle . You can kind of see the box. I can tell you the exact size I used, when I get to work tmw.
Posted: Sun Mar 22, 2015 7:54 pm
That would be great thanks. Maybe I'll stop in at my local Napa tomorrow and see if they have them as well.
Posted: Mon Mar 23, 2015 10:41 am
by Colin2750
It's an M6
Posted: Mon Mar 23, 2015 10:48 am
Thanks guys. I'll order one from the tool truck when it stops in. Napa didn't have that kit.
Posted: Mon Mar 23, 2015 12:29 pm
by Dutchbroracer
DE80q wrote:Thanks guys. I'll order one from the tool truck when it stops in. Napa didn't have that kit.
They are called Torx Plus sockets. The size you need to order is TP30. Here are some pics. Sorry for the links, the pics are huge.
http://i242.photobucket.com/albums/ff24 ... o1j79.jpeg
http://i242.photobucket.com/albums/ff24 ... mwray.jpeg
http://i242.photobucket.com/albums/ff24 ... 2uahs.jpeg
Posted: Mon Mar 23, 2015 1:33 pm
by yodasfro
Posted: Mon Mar 23, 2015 2:44 pm
by Dutchbroracer
Your PB picture shows a regular torx. While Austin is correct (as usual lol) in that RIBE are different then Torx Plus, if you have ever seen them side by side there is not a whole lot of difference. Ive been using torx plus on both types for years now with not one strip. :idunno:
http://i242.photobucket.com/albums/ff24 ... gpzxd.jpeg
