Ceramic Coating 5-cyl Wastegate
WRC
Post by WRC »
Anybody know why the OEM 5-cyl Wastegate has heat sink fins?
Would coating it with ceramic coating be a bad idea because it will retain heat?
Or would a high heat thermal dispersant be better for that?
Thanks in advance.
Wiley Rankin Coffin
Mine
'87 Alpine White 4KQT e85 Xona - Toy
'16 Deep Black Pearl Golf R Manual - Stockish
Hers
'06 Deep Sea Blue 2.0T A4 APR Stage 1
Re: Ceramic Coating 5-cyl Wastegate
It has heat sink fins to disperse heat...
The reason for dispersing heat is (in my opinion) for ensuring proper valve clearances and to protect the diaphragm. Definitely don't use something which will retain heat inside.
CCPcoatings
Post by CCPcoatings »
WRC wrote:Anybody know why the OEM 5-cyl Wastegate has heat sink fins?
Thanks in advance.
If it is designed with a heat sink, then ceramic coating it to further retain heat would not be advised. Having it coated with a thermal dispersant would be much more beneficial. Unfortunately, on a part like this I can't imagine you would notice any improvement for your efforts.
WRC
Post by WRC »
Thanks for the replies guys.
That's what I figured. High temp thermal dispersant it is.
Just looking for a coating that will handle the heat. Just doing some beautification not expecting performance improvement.
Wiley Rankin Coffin
Mine
Hers
CCPcoatings
WRC wrote:Thanks for the replies guys.
What temps are you seeing?
WRC
Post by WRC »
CCPcoatings wrote:What temps are you seeing?
Not sure of surface temps, but EGTs are in the 1200-1500 range.
Wiley Rankin Coffin
Mine
Hers
