C5 40v 6spd swap Help.
Posted: Thu Jan 28, 2016 4:55 pm
by scubagli
Hi,
Fellas I just picked up a 2000 a6 4.2 with a bad trans. I intend to 6spd swap the car. I've been poking around for about a week looking for a comprehensive diy, but haven't found a real good guide. I need to know which flywheel clutch combo will work, as well as if the ecu needs a flash or just soft coding adjusted with vagcom. Also looking at advice on which trans to use, I have access to an S4 01E as well as a 3.0 01E FYF code. I'm leaning towards the FYF I've heard it has the flexible main shaft and wide first. Any insight would be helpful...if anyone has pinouts for reverse lock out, clutch and brake switches that would be helpful too. Thanks for any and all insight.Image
Re: C5 40v 6spd swap Help.
Posted: Fri Jan 29, 2016 2:29 pm
by the german
b5 S4 01E is wide first as well. I believe the ECU can be recoded for manual trans using vagcom in this generation which is pretty handy. Years ago I found some threads on another forum discussing it while researching for my own planned swap (manual into a 4.2 Allroad).
I'm not positive but I *think* a b5S4 clutch and flywheel may work but someone please check me on that. Otherwise I think it may require importing a flywheel from europe.
Good luck!
Good luck!
Posted: Fri Jan 29, 2016 8:53 pm
Scott DeWitt wrote:Front Allroad heavy duty axle upgrade kit $695
Mini harness $75
Mounts $200
New Prop shaft $650
PEdal assembly minus hydraulics $200
Hydraulic assemlby (line, slave and master (new) $300
Rebuilt shifter assembly $300
Resurfaced DMF flywheel $250
RS4 clutch kit $435
Mounting hardware $75.00
Scott
I asked Scotty at Advanced Automotion for a quote to 6-sp swap an Allroad with a junk auto trans, that's what he replied. I was this_close to buying one to swap for a cheap family wagon, but didn't. Because 2.7t.
Posted: Fri Jan 29, 2016 9:10 pm
by scubagli
I've got 95% of the parts, need a prop shaft, drivers axle, then I need to know about ecu junk....found Derracudas thread on mg, it was helpful.
Sent from my SAMSUNG-SM-T337A using Tapatalk
Posted: Sat Jan 30, 2016 12:00 am
by 90quattrocoupe
Manual into an A6 4.2, This thread should tell you everything you need to know. Starts on page 5.
http://www.motorgeek.com/viewtopic.php? ... &start=100
Greg W.
Posted: Sat Jan 30, 2016 5:45 am
by scubagli
90quattrocoupe wrote:Manual into an A6 4.2, This thread should tell you everything you need to know. Starts on page 5.
Greg W.
Thanks I hadn't read the audi world link.
Posted: Sat Jan 30, 2016 8:14 am
by audidub
I've been slowly working on this swap in my s6, I ended up going with the jhm flywheel kit which uses an aluminum flywheel( unknowing to me was made by 034) designed to use a stock rs4 pressure plate. The rs4 engine is rated at 340hp same as my engine so should have a nice stock feel and hold fine, the kit costs 1k though. I had the ECU recoded to euro 6spd and then you still have to go in with the vcds and change a bunch of setting, there is a link I had found the spells most everything out,http://www.audizine.com/forum/showthread.php/416298-Recoded-ABS-module-for-manual-trans-now-get-quot-incorrectly-coded-quot-fault
I will try and find the other link I used for the wiring, though still haven't been able to get the neutral switch working for whatever reason. But we did jump the starter and it fired up and moves so just a little tweaking left
Hope this helps :beer:
Posted: Sat Jan 30, 2016 10:09 am
by scubagli
audidub wrote:I've been slowly working on this swap in my s6, I ended up going with the jhm flywheel kit which uses an aluminum flywheel( unknowing to me was made by 034) designed to use a stock rs4 pressure plate. The rs4 engine is rated at 340hp same as my engine so should have a nice stock feel and hold fine, the kit costs 1k though. I had the ECU recoded to euro 6spd and then you still have to go in with the vcds and change a bunch of setting, there is a link I had found the spells most everything out,http://www.audizine.com/forum/showthread.php/416298-Recoded-ABS-module-for-manual-trans-now-get-quot-incorrectly-coded-quot-fault
Thank you, I'm picking up that clutch kit used for $245, there was no 6spd sedan. I'm not sure how diffrent the s6 and a6 4.2 are...I'll have to dig a little deeper into that. It seems you can just leave the tcu and all its junk plugged in.
Posted: Sun Jan 31, 2016 8:11 am
by audidub
From the research I did at the time the best option I found to use stock components was a b5 2.7 fw with 3mm machined off the friction surface and the pins modified and then a stock b6 rs4 pp and disc. I had found this info in a couple places. I just decided in the long run I wanted new parts vs sinking money into a used dual mass fw. You will need to use a 2.7 trans spacer and remove some material from it for one of the starter bolts to fit, Hope this helps. And if u find a better description for wiring in the neutral safety switch post it up please.
Posted: Sun Feb 21, 2016 8:38 pm
by my2000apb
scuba gli i have a prop and axles if ya need em, hit me up
