Manual windows in b3 90
Rabbitracer43
Are there any options to switch to manual Windows in my b3 90?
Re: Manual windows in b3 90
From what I found, nothing easy.
1988 Audi 90Q 1.8T swap
2003 VW Jetta TDI
1978 GMC High Sierra
2015 Touareg Lux
http://dubsinthebuff.com
2003 VW Jetta TDI
2015 Touareg Lux
europe. even b4 avant/saloon came with themRabbitracer43 wrote:Are there any options to switch to manual Windows in my b3 90?
why change them? Out of all the things that audis give trouble with, I haven't found the power windows to be a problem area on the cars I've owned.
- paradox11235
I have a bad window reg in my B3, if I could get manual windows for cheap I would. But I'm also gutting the whole car... Otherwise I'd just find a good used reg.
If this is a B3 Coupe you can get a regulator repair kit from a Cabriolet. Provided the guide pulleys are in good shape on the window regulator frame the repair is straightforward.
Nulla tenaci invia est via
