1990 90Q Stroker 2.6 20v
Posted: Wed Mar 04, 2026 3:49 pm
This is my 1990 Audi 90 Quattro 2.6 stroker build. Really wanted to build a short deck stroker.
Finally remembered to post here.
Parts list so far:
2.3 7A block - rod clearance die grinding needed
2.5 AAF crank
2.3 7A head and cams
2.0 CCTA rods/pistons
12.9 Main bolts
2.5 AAF oil pump
Early 7A Bag-O-Snakes header w/vband
034 Motorsport 7A injector adaptors
034 Motorsport Silicone block breather
034 Motorsport Delrin Engine mounts
034 Motorsport Density Transmission/Diff mounts
034 Motorsport Delrin rear diff mount
034 Motorsport Rear Delrin Control arm Bushing
034 Motorsport Aluminum subframe bushings
034 Motorsport Polyurethane Snub Mount
Powerflex Black Series front control arm bushings
New Febi Inner and outer tirerods
New rear control arms
Bilstein Sports Struts/Shocks
H&R Sport Springs
Stainless braided clutch line
B3 Euro Headlights
14point7 SLC Free 2 with LSU4.9 wideband
0280155759 30lb injectors
034 Reman crank dampener
Ebay RS2/S2 Aluminum Radiators
G60 Calipers
HEL Stainless Brake lines
Brembo sedan front rotors 276mm
Mako Driveshaft Center bearing
Mako Driveshaft CV's
Verkline Top Mounts Front
Verkline Rear Track Rods w/ ARB
Febi top mounts Rear
New wheel bearings
New Empi Sedan 20v front/rear CV shafts
Parts list so far:
2.5 AAF crank
12.9 Main bolts
2.5 AAF oil pump
H&R Sport Springs
B3 Euro Headlights
G60 Calipers
New wheel bearings
