E85 Content Sensor Options
Posted: Tue Nov 19, 2013 3:25 pm
by mushasho
Coincidence?
$199
Zeitronix
$225
Item #4 New Style Flex fuel sensor GM 13577394 or 13577379 (not sure if these output Freq or Voltage) For GM 3.6 engine
$66 bucks
Gm Parts Direct and search part #13577394
All of these appear to be the same. I'd like to know if there's a way if they output frequency or voltage...
Re: E85 Content Sensor Options
Posted: Tue Nov 19, 2013 3:53 pm
by EDIGREG
Posted: Tue Nov 19, 2013 5:47 pm
by mushasho
I found a lot more hardware specific info here on the
MR2 Owners Club Message Board ... Covers most of the available sensors from the GM lineup...
I was under the impression that the newer sensors output in voltage as opposed to frequency. Seems as though it's the gauges/lcd displays that come prepackaged in these kits that convert/output the frequency signal in volts for more compatibility with standalone ecu's. Lucky for me VEMS can use both, in fact frequency is said to be less "crude" in it's output resolution than a converted volts output.
Here's the
Dynosty Kit where they list output in volts... it was misleading at first but I think I got it now...
Posted: Tue Nov 19, 2013 8:10 pm
Zeitronix also claims to grab fuel temp, if that helps you.
Re: AW: E85 Content Sensor Options
Posted: Wed Nov 20, 2013 11:47 am
by audis2turbo
Vw part.
It is much cheaper and works good and it is the same as Zeitronix
Gesendet von meinem GT-I9100
Posted: Sat Dec 21, 2013 8:23 pm
by pilihp2
Posted: Thu Jan 02, 2014 12:36 pm
Fantastic thread. Thanks guys
Posted: Sat Apr 05, 2014 10:12 am
by Marc
got a part number for the connector kit anyone?
Posted: Sat Apr 05, 2014 10:17 am
by Marc
to answer my own question, its a delphi GT150.
