Page 75 of 83
Re: Derracudas zermatt 20vt 6spd 4kq project
Posted: Thu Oct 07, 2010 7:20 pm
by turboit
love the absolute attention to detail. I want my car built like this haha
Posted: Fri Oct 08, 2010 9:43 pm
by derracuda
Posted: Fri Oct 08, 2010 10:24 pm
Sounds great Derek!!!!!! I love it! Hows that 6spd feel?
Posted: Sat Oct 09, 2010 2:15 am
by chadlundy
Damn! that thing is lookin/soundin mean derek!
Posted: Sat Oct 09, 2010 8:16 am
by derracuda
Posted: Sat Oct 09, 2010 8:34 am
xD Oh ya... That looks veeeery nice Derek!
Posted: Sat Oct 09, 2010 3:44 pm
by derracuda
frustration is oozing from my pores now. i'm not a computer genius, but my friend is (IMO), he spent over two hours fiddling with COM port settings, two laptops, i got ahold of nate and we finally got one computer to talk with my ECU. the latest firmware update is in place, went to start it, nothing, no WDBG readings and RPM is wackadoo, which it was perfectly fine before the firmware update. started and drove fine, i didn't touch anything under the hood while we updated the computer end. i'm not seeing anything standing out in front of me that a setting is changed, but perhaps i'm just an idiot.
then unplugged it to go charge the laptop, plug it back in, no dice..... tried numerous COM port setting and nothing.
*sigh* i'm sick of this computer crap. it's frustrating to no end to sit and fight this instead of working on a tune and using brain cells for that :( not to mention it helps to keep from building that trust in the setup.
i need help :(
Re: Derracudas zermatt 20vt - needa lil' IIc help please
Posted: Sat Oct 09, 2010 4:03 pm
by apavlov13
Device manager should tell you which COM port the dongle assigns to.
Oh and your car is sexy beyond belief in every aspect! Kudos!
Posted: Sat Oct 09, 2010 4:07 pm
by SeStone
Switch the pins on the VR sensor, the two that aren't the shield.
Sam
Posted: Sat Oct 09, 2010 4:08 pm
by a_CQ
I know your feelings..
Are you using the same USB port all the time?
Sorry, I don't know if I can be of much more help....you'll get it though, tune it well and then it will run nicely for a long time. That's how my car was, bunch of little things to figure out, but once tuned, it runs perfect.
Posted: Sat Oct 09, 2010 4:09 pm
by a_CQ
Sam, why would switching VR pins help his PC communicate?
Posted: Sat Oct 09, 2010 4:17 pm
by derracuda
apavlov13 wrote:Device manager should tell you which COM port the dongle assigns to.
we've been through that dozens of times now. the new firmware gives more port options, but it always says port 3 is present, and the rest are "failed". and we've selected that #3 to be used on both the ECU and the laptop to partial avail.
Posted: Sat Oct 09, 2010 4:18 pm
by SeStone
The new firmware is pickier about the type of VR signal it interprets as a tooth...if the pins are technically backwards, it would work perfectly fine in the old firmware, but not in the new. On top of that, it would read crazy RPM counts at low RPMs or while cranking. One of the A4s I work on did that, that's all i know.
Sam
Posted: Sat Oct 09, 2010 4:45 pm
by TheArchitect
If you did an firmware update, did you load the set file that 034 provided?
No way in hell it will run without defaulting all the new parameters that your old firmware has scrambled.
Also the new software is a bit smarter on ports, but keep in mind that COM3 and COM4 very often are set to the internal
analog modem, and if the port exists, the new software doesnt tell you "fail" for that port.
This doesnt mean that your USB dongle is at that port, but rather than there is a valid COM port there, obviously the
modem is not going to let you connect to the ECU.
Look at the device manager to know where the USB driver put the port#, sometimes it puts them in the high teens.
Posted: Sat Oct 09, 2010 6:15 pm
by speeding-g60
D, the garage code. texted it.
if you need the garage laptop its right there where it always is.
Chub asks if you will feed his fish and his froggys
Posted: Sat Oct 09, 2010 9:43 pm
by derracuda
TheArchitect wrote:If you did an firmware update, did you load the set file that 034 provided?
ok, i fiddled around with it more until the thing started talking again (took a break this evening), and got the .Set file uploaded. still no start... or do i need to check anything else?
Posted: Sat Oct 09, 2010 9:52 pm
by derracuda
also, do i need to change the pins around for the VR sensor? i'm getting no signal essentially that the engine is turning over. RPM readings are just random, 1k, 4k, 0, etc when i am cranking now.
Posted: Sun Oct 10, 2010 4:39 am
by ktownboostn
Might as well give it a try. Sounds like it could be the issue
Posted: Sun Oct 10, 2010 7:23 am
by TheArchitect
derracuda wrote:TheArchitect wrote:If you did an firmware update, did you load the set file that 034 provided?
After any FW update, you should always make sure the ECU output data and all the sensors make sense before trying to start.
Posted: Wed Oct 13, 2010 5:18 pm
by derracuda
newt wrote:derracuda wrote:also, do i need to change the pins around for the VR sensor? i'm getting no signal essentially that the engine is turning over. RPM readings are just random, 1k, 4k, 0, etc when i am cranking now.
This firmware is more particular about the VR signal. If your sensor is pinned backwards you're not going to get good readings. Give the pin-flip a test and see if that cleans up the triggers. You'll need to re-zero the motor after this as well of course.
Pins were flipped and the car started right up. i tweaked on the ign. maps a bit from some screen shots Jimmy G. sent me, and either his ign. settings fixed it, or the VR wires. but it runs smooth to 7k now
i also am finally getting some logs and things look fairly ok, a little rich, but otherwise ok.
Posted: Wed Oct 13, 2010 6:00 pm
by WRC
Man I bet that was frustrating.
Glad it wasn't too hard of a fix.
Posted: Wed Oct 13, 2010 7:24 pm
by Wheeljack
SeStone wrote:Switch the pins on the VR sensor, the two that aren't the shield.
Sam
:cheers: Sam gets another cookie.
Posted: Wed Oct 13, 2010 8:50 pm
Woot!!!!
Re: Derracudas zermatt 20vt - 6spd - 25 whaaat?
Posted: Wed Nov 03, 2010 7:18 am
by derracuda
P
S
I
pretty stinkin' insane.
WG line fell off last night and i hit 25psi. i can't drive the car anymore. i forgot what adrenaline feels like and my body is still recovering. back the workmobile to recover....
Posted: Wed Nov 03, 2010 7:22 am
by Hybrid_Hatch
I'm jealous! I need to get my fix! ... calling hank...
